Overheating motor
  • pribco
    • Feb 2011
    • 109
    Overheating motor
    While waiting for the glue to dry on the SkidaddleTOO I am making I have constructed a homemade "rescue boat." out of some left over luan. Painted and pollyied. Looks like a WW2 landing craft.
    24" long--
    Runs terrific but motor really overheats. Motor is an Kyosho Lemans Stock 05. The number 1200 in on the package-rest is in Japenese.
    Prop is 1 3/4 inch-- It is the CEN 42mmx1.4
    Battery is standard 1500 ahm.7.4 vts.
    No cooling system.
    Question--could this be a 6 volt motor<
    Is the prop to big??
    The motor (left over from long ago) seems to be for a car--should I get a marine motor?
    Any advice appreciated.
    Bill
    If you step on my tail, you had best make plans to deal with my teeth!!!
    • 7990
    The prop is way too big for that motor in a non-planing hull with submerged drive. Go to something like an x430 (1.18" diameter). It is a 6-cell (6 x 1.2 volts) motor designed for a car, but we used to use them in boats all the time. The biggest problem here is far too much prop.
    • pribco
      • Feb 2011
      • 109
      Fluid-thanks, I sort of suspected that-to bad because it moved pretty smartly before overheating.
      As a follow up-
      1. When I go to the smaller prop, will I see a fall off in preformance??
      2. Should I go with the Dumas 6v, 10,000 rpm motor or the Aquacraft 540 brushed motor?-if so what prop??
      Thanks, Bill
        • 7990
        I'm not familiar with either motor. You can expect a fall off in performance with the smaller prop, how much is hard to predict. A prop no larger than 1-3/8" in diameter, the Octura plastic x431 is pretty good.
        • Alexgar
          • Aug 2009
          • 3522
          That's a onroad motor with a 45 47 mm prop some nice bl motors would overhead with that Prop load I say a 531 prop on 25000 would move a small hull well but a heavy hull needs a low kv big prop
          • pribco
            • Feb 2011
            • 109
            Alexgar-thanks for the reply but I don't understand.
            With the motor that is installed, what prop--I tried a smaller one this morning in the bathtub and seems to run cooler.
            OR--should I put in the Dumas motor (10,000RPM--if so what prop-
            OR - the Aquacraft (brushed,540) If so what prop?
            Thanks, Bill
            • Alexgar
              • Aug 2009
              • 3522
              sorry i was posting on a phone not to easy
              i would go with the aquasport motor and a octura x531 or a stock prop from a blackjack nitro ive had good luck with both of these in smaller hull
              • pribco
                • Feb 2011
                • 109
                Alexgar--when you say low kv, what do you mean??
                Why the Aquacraft motor instead of Dumas?--just more rpm/torque etc??
                I am sure you realize this is not a plaining boat--picture Omaha Beach, 1944
                • Alexgar
                  • Aug 2009
                  • 3522
                  Kv means rpm per volt a high torque motor with a big prop or a faster motor with a smaller prop choose one but a fast motor with a big prop will burn up in. No time
                  • pribco
                    • Feb 2011
                    • 109
                    Thank you Sir--put the Aquacraft in this afternoon--will give it a test run in the bathtub later. Put a 1.1/4 " prop on-
                    Will order the prop you sugested next time I order from Offshore, but p/h kills a small order.
                    • Alexgar
                      • Aug 2009
                      • 3522
                      yor can buy the proboat nitro prop at the hobbystore for like 3.99
                      • pribco
                        • Feb 2011
                        • 109
                        Thanks to everyone--last night put in the Aquacraft motor and a 1 1/4 " prop--tried in bathtub the morning--what a difference--Pulls twice as hard, motor stays cool for a steady 5 min run at full speed. Water was almost pushed over the side of the tub.
                        Would go to the lake and try today but income taxes need to be done-(at least the $ will be wisely spent!!!)
                        My trophy bride thinks I have lost it--a 70 y/o man playing with boats in the bathtub--at least it's not a rubber ducky!!
