tube grease
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1092
    tube grease
    Hi, I was wondering if this grease http://www.inoxed.com/mx8.htm would be any good to use on the drive shaft and in the tube? I've just rebuilt my stuffing tube due to a failed attempt with my first and while in the shed I noticed I have a full tube of this grease and it seem's to read well, I'm hoping someone may have tried it or may at least know if it'd work well?
    "Gimmy Toyz for FUN"
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1092
    Anyone, tried or even heard of it?
    • m4a1usr
      Fast Electric Addict
      • 2038
      I have heard of it but never tried it yet. Has all the qualities to use as drive line lube. I guess it depends on how much you get a tube for. Since I only buy by shaft grease in gun sized tubes its probably a great deal when you average it out over the years. Nice thing about grease is you can thin it out to make it go further.
      John
      Change is the one Constant
      • millzee
        Ozzie Bloke
        • Nov 2010
        • 1092
        I just wanted to throw this question out again b4 I try this stuff
        • pyroM!KE
          • Jan 2011
          • 375
          I have been using premium Marine wheel bearing grease form O'Reillys with good results..Of course I re-grease every 3 or 4 runs..
          • Alexgar
            • Aug 2009
            • 3534
            Seem like it will be ok
            • millzee
              Ozzie Bloke
              • Nov 2010
              • 1092
              I tired it yesterday and it seems to last a lot longer than the grimracer grease I've used, I went to re-grease after the 4th run and it had held up very well, kept it's color and thickness and the boat seemed smoother, maybe. I will continue to use this as it has lasted twice as long as the other, it doesn't oze out everywhere and I had no problems at all. I temped the drive line through out all my runs and the hottest it got was 45c - 113f at the end of a 5 minute run, and that was the last run of the day. A big from me.
