ESC fluid?
  • Gunny
    Zombie Hunter
    • Feb 2011
    • 71
    ESC fluid?
    What would a yellowish fluid coming from the esc mean? Ran the boat for about 20 seconds at only about 1/4 throttle than it stopped. Reeled her in and popped the hatch and there was yellow fluid. Looked like it came out of the esc.
    A bizarre incident in the outskirts of an American suburb. It was later revealed the disaster was caused by the T-Virus. A mutagentic toxin created by Umbrella Incorporated for use in bio-weapon experiments. Don't worry the zombies are looking for brains, you're safe.
  • m4a1usr
    Fast Electric Addict
    • 2038
    Oooch. Thats probably the oil from one or more of your caps. If thats the case do not use that speedo untill you determine which one/ones are leaking. Having said that it could also be the silicone oil coming out of suspension if you have a heat sink on the speedo and providing that indeed a liquid based heat transfer goo was used. Most use thermal pads now so its a bit rare to hear of that stuff being used anymore.
    John
    Change is the one Constant
    • Gunny
      Zombie Hunter
      • Feb 2011
      • 71
      Looking at the caps they look fine. I didn't even get a chance to run the boat hard so I don't think there was alot of heat build up or spike. Its a seaking 120.
      • m4a1usr
        • 2038
        Could it just be greasy/oily water coming in from your stuffing tube? Is it even oily fluid?
        John
        • Gunny
          Zombie Hunter
          • Feb 2011
          • 71
          Didn't seem oily. It was definitely coming from the esc though. The esc doesn't work, even if I use the program card for it, the card doesn't even turn on.
          • Gunny
            Zombie Hunter
            • Feb 2011
            • 71
            I thought it was water that got in the esc and the yellowish fluid was some form of coating from the circuit board.
            • mgcrimson
              • Oct 2010
              • 49
              "A bizarre incident in the outskirts of an American suburb. It was later revealed the disaster was caused by the T-Virus. A mutagentic toxin created by Umbrella Incorporated for use in bio-weapon experiments. Don't worry the zombies are looking for brains, you're safe. "
              Ahhh, would that be Resident Evil?
              ROLL TIDE ROLL!
              ML Boatworks PS295, Dumas Hot Shot Sprint 3.5, JAE 21FE, Yellow Jacket Outrigger,
              • Gunny
                Zombie Hunter
                • Feb 2011
                • 71
                Yes! You are quite correct.
                • Gunny
                  Zombie Hunter
                  • Feb 2011
                  • 71
                  Also guys, it does appear that the caps are slightly bulged and not flat. Would it be easy to replace these caps? Replace with which ones? Or is the Seaking 120 dead? I might have to just break down and get the seaking 180 like I wanted to.
                  • LiPo Power
                    DJI Drone Advanced Pilot
                    • May 2009
                    • 3186
                    Well, if you can still arm your ESC and run the motor than your caps are still ok.
                    Post pictures please so we can see the caps...
                    Maybe you can capture your esc problem and post it also....
                    Canada
                    • Gunny
                      Zombie Hunter
                      • Feb 2011
                      • 71
                      ESC wont arm at all. let me find my digital camera and i'll post pics...
                      • Gunny
                        Zombie Hunter
                        • Feb 2011
                        • 71
                        Here's the pictures.
                        [ATTACH]42881[/ATTACH][ATTACH]42882[/ATTACH][ATTACH]42883[/ATTACH][ATTACH]42884[/ATTACH]
                        • Diegoboy
                          • Mar 2007
                          • 7244
                          Caps are popped
                          • Dustin Sontag
                            • 53
                            yup
                            • m4a1usr
                              • 2038
                              Originally posted by Diegoboy
                              Caps are popped
                              And how! Seen that many times over the years. Dont try and operate the esc. Its probably already toast. But get some more caps installed before you do anything. You need any,.... contact me. I have a huge inventory.
                              John
