Schulze ESC Wiring + Wire Length Question
  • domp444
    • Jul 2009
    • 846
    Hey guys. On the Schulze 40.160 ESC's, there are two red and two black battery wires. I'm guessing these are for parallel use, but I just want to make sure I am correct.
    My second question is what the length between the motor to ESC and ESC to battery should be. I think it should be 8" ESC to battery, but not sure about ESC to motor.
    Thanks!
    SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
  • RaceMechaniX
    • Sep 2007
    • 2833
    Yes, the twin battery wires are for paralleling packs. You want to keep all wires short, but particularily the motor to esc wires. I would try to stay under 4" if possible.
    Tyler
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • domp444
      • Jul 2009
      • 846
      Thanks! I just checked, my esc to motor wire total length is 5". Will this be okay? I will try to keep the battery to esc wires short as well.
      • RaceMechaniX
        • Sep 2007
        • 2833
        As long as you are using good quality wire and no extra connectors you should be fine.
        Which motor are you using?
        Tyler Garrard
        • domp444
          • Jul 2009
          • 846
          Not sure what type of wire it is, as it came with my boat. It's probably good quality though. I am running 2x Neu 2215 1.5y motors. There are only connectors where necessary.
          • RaceMechaniX
            • Sep 2007
            • 2833
            I have that exact combo in my conquest although its a single. I hope you are using the older style Schulzes not the new ones?
            You can read the pack posts where I had headache after headache getting the newer syle Schulzes to work with the Neu 2215/1.5Y.
            Tyler Garrard
            • domp444
              • Jul 2009
              • 846
              I'm not sure which ones I have. How can I check? It says V-16 under some numbers which seem to be dates.
              I hope I don't have any problems!
              • RaceMechaniX
                • Sep 2007
                • 2833
                You probably have the new ones. Are the caps on the laying over towards the center of the board or hanging off the end of the board?
                Tyler Garrard
                • domp444
                  • Jul 2009
                  • 846
                  The caps are hanging off the side. One of them is used and one of them is new. They both look exactly the same though.
                  • RaceMechaniX
                    • Sep 2007
                    • 2833
                    That is good! They are the older style which seem to work much more reliably with Neu motors. The newer Schulzes have some more advanced controls it seems that have difficulties with the low inducatnce Neu motors.
                    Tyler Garrard
                    • domp444
                      • Jul 2009
                      • 846
                      Oh that's good to hear! I was getting a bit worried. Thanks for the info!
                      I can't wait to get this boat in the water, haha.
                      • RaceMechaniX
                        • Sep 2007
                        • 2833
                        This is the new style:
                        Tyler Garrard
                        • domp444
                          • Jul 2009
                          • 846
                          Oh then I definitely don't have that.
                          • RaceMechaniX
                            • Sep 2007
                            • 2833
                            You should be good to go then.
                            Tyler Garrard
                            • Doug Smock
                              Moderator
                              • 5272
                              Just in case you need it. From the Shultze website.
                              The future (and other types e. g. smart or slim ) electronic speed controllers have been designed to operate correctly with a cable length between battery and controller at a maximum of 20 cm (7 inch) each lead.
                              In some installations it will be necessary to increase the length of the battery cables. In this case it is necessary to install additional low-ESR decoupling capacitors. The installation of these additional capacitors allows the increase to a total length of battery cables to as much as 30-50 cm (12-20 inches), depending on the motor load or 30 cm when using not inline (not end-to-end) soldered packs (12“ pos.+ 12“ neg. cable between "saddle-packs" and controller).
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
