is it a bad idea to add a wing on a cat? ive read a thread where this one guy that owns 3 expresscraft thundercats and stated that they tend to run wet. also, if you notice on the rear sides he has vents. i like them and was wondering if anybody knows where i can find them or how to make them. ideas are surely welcomed!
is this a bad idea?
Tags: None
Nice thought. But I found my cat needs more down force at the nose when it reaches 80+mph, not at the transom. Different hulls might have diff characters though. But I've seen a a lot of cat stability problems at high speeds, all of them behave like their noses tends to go up when speed goes to a certain level, then soon within a blink of an eye they ended up with a brilliant fly dance in the air. -
Bad idea, that wing adds downforce exactly where it is NOT needed, plus a lot of unnecessary drag. The vents are for the gas engine and are available from several gas boat suppliers. Unfortunately he is not a very knowledgeable gas boater, he apparently does not have enough air inlet area to keep the motor supplied with cool air.
.If the #2 pencil is the most popular, why is it still #2?Comment
Nice thought. But I found my cat needs more down force at the nose when it reaches 80+mph, not at the transom. Different hulls might have diff characters though. But I've seen a a lot of cat stability problems at high speeds, all of them behave like their noses tends to go up when speed goes to a certain level, then soon within a blink of an eye they ended up with a brilliant fly dance in the air.If the #2 pencil is the most popular, why is it still #2?Comment
I came up with a similar idea, to add a small slope at the nose. It will have nearly zero effect at low speed but will some downforce when speeds up. This is just an idea, haven't got a chance to give it a try yet.Comment
140+km/h actually, yes, on another model. When I try to go faster I just can't stop my HPR115 from it's tendency of going flying.
I came up with a similar idea, to add a small slope at the nose. It will have nearly zero effect at low speed but will some downforce when speeds up. This is just an idea, haven't got a chance to give it a try yet.If the #2 pencil is the most popular, why is it still #2?Comment
An easier and more effective solution is to use a tunnel air dam about 3-4" back of the nose. About 1/2" high, it disrupts the air in the tunnel and reduces lift. I had to use one plus some trim tabs at the back of the tunnel (to lift the stern) to get into the mid-80s with my SprintCat. It has a lot more lift than an HPR, etc.
.Comment
Fluid's advice is spot on. He gave me the same for my Sprintcat. The airdam DOES work, and well.
I cut a piece of pool noodle square anf fitted it in the tunnel. However, it is unnecessary unless you're hauling some major butt. I'd run her first to see how she handles, and work with strut adjustments and props.Comment
I run outrunner (OR) motors in my big cat and like them, they get hot but I do hard short runs so it works for me.
They can be fun but have their own issues for cooling (if needed).
fwiw I am in love with OR's for now, I run 3 hulls with them and will have 2 more on the water with OR power soon. I may be biasedSee it....find the photos.....sketch it it....build it........with woodComment
