should you grind flat spot for drive dog??
  • 6sHyper
    <<<Surfs up!
    • Jan 2011
    • 597
    Just installed a new one piece flex cable system in my apparition, this has a 3/16" smooth round stub and there is no flat spot for the drive dog, should i be grinding an area for the drive dog set screw or not?? thanks.
  • Doby
    KANADA RULES!
    • 7280
    yes
    Grand River Marine Modellers
    • carlcisneros
      • Jan 2010
      • 1218
      OH, HELL YES!!!!!!!!!!!!
      other wise, it is watch the shaft go round and round and the prop staying in one place.
      Been there, done that MANY years ago. LOL
      • the savy fluxer
        • Jan 2011
        • 83
        im going to have the same issue next week, when we grind the flat spot do we solder that spot or just leave it bare and how much of a flat spot do we grind?
        thanks for your input
        • 6sHyper
          <<<Surfs up!
          • Jan 2011
          • 597
          I grinded a small flat spot with my tiny dremel bit, then i finished it with the thin edge of a file so its perfectly square and flat, worked great its a 3mm flat spot.
          • the savy fluxer
            • Jan 2011
            • 83
            perfect thanks man.
            • Grimracer
              • Nov 2008
              • 662
              I like to make a drill point in the shaft for the set screw to fall into.
              Its a tic stronger then a flat spot.. but a flat spot works too!
              Grim
