Brushless efficiency ??
  • Igoreski
    • Apr 2010
    • 77
    Can someone with a good brushless background answer a couple questions about KV / voltage efficiency.I ran 2- 380XL 2930kv motors on 3s which was fast but drew a lot of amps.If I ran the same size motor / prop combo with a lower kv around 1480kv but much higher voltage 6s would that run lower amps and be more efficient given that the RPMs would be about the same.[2] Would two 5000mah 30c 3s joined in series give you 6s but cut your run time in half compared to running the same battery packs by themselves,one on each ESC.
  • steveo
    • 1454
    #1 higher voltage = less amps at same rpm- in perfect world you gonna draw half the amps with 6s
    #2 i would think that your run time might be the same your drawing less amps at 6s but with only 5000 mah feeding both motors, but i am not an expert
    • steveo
      • 1454
      6s per motor would best for amp draw and runtime
      • Igoreski
        • Apr 2010
        • 77
        Thanks, I wanted efficiency but wanted to use my abundant supply of 2s & 3s battery packs.
        • drwayne
          • May 2008
          • 2981
          Use 3S2p with your 2930's for double runtime ...
          6S1P with1480Kv equals similar as 1930 on 3S1P runtime
          W
          • Igoreski
            • Apr 2010
            • 77
            The 3s on 2930 is the amp draw problem so adding 2p would only add weight making it worse.I have 2 120a ESCs and 2 motors.
            • drwayne
              • May 2008
              • 2981
              W
              Doh.
              6S1P Vs 3S1P.. of course it has twice runtime.. but similar total rpm at prop.
              Late night here in Au ..getting my thoughts confuddled.!
              W
