is it recommended to add caps to my seaking 180a esc? im installing this esc in my ul1 and running it on 6s with a tacon 1700kv and starting with a y536 then if temps dont bit*h me out ill up the prop to m440. should i add caps to the t180? if so, how do i do this?
should i add caps to my t180?
Tags: None
I use this and disconnected the internal bec
I have no problem running 6s.
http://www.offshoreelectrics.com/pro...035-lv&cat=136 -
How old is it and what it says on the caps (specs)?
DJI Drone Advanced Pilot
CanadaComment
ohh 1 side of the contacts on the bottom of the board goes on the neg wire of esc, and the other on pos (respectively) correct? and this aids in doing what?If the #2 pencil is the most popular, why is it still #2?Comment
Obviously I am talking about your ESC and you never stated that you do not have it yet other than in your last respond #7.....
If your yet to come ESC will have 3 x 35V, 1000uF caps you shoud be save becouse these are the new caps they are installing on them.
If you still go ahead and decide to put more caps you can see what I did here ( other than Etti board ):
http://forums.offshoreelectrics.com/...ad.php?t=21512
Your welcome.....DJI Drone Advanced Pilot
CanadaComment
Your welcome.....If the #2 pencil is the most popular, why is it still #2?Comment
