bad throttle habits
  • RIPFENCE
    • Sep 2009
    • 1332
    bad throttle habits
    which is worse for speed controllers? a lot of on and off the throttle or
    cruising a half throttle for long periods with some full out bursts now and again..both cannot be good but which is the lesser of the 2 evils? it seems like the lakes i run on have chop at all times and i am always on and off the throttle..also i am going to trying a hot setup and i want to do the best i can to keep happy esc's..
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    With no design ESC experience I would suggest the latter as the worst scenario, as you will be running the boat in a wet condition most of the time
    Douggie
    • jac4412
      FE Addict
      • Jun 2010
      • 425
      Rip, neither is good for the ESC, but your best bet is to run your boat at full throttle, youre going to get alot of amp draw and put alot of strain on the ESC going at half throttle for long periods of time, especially if youre going to burst it open every once in awhile
      JAC4412 RC
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7116
        I like to use lower voltage (fewer cells) for choppy conditions - which allows for 2P configurations as you still need the weight.. that way you don't have to be evil at all
        "Look good doin' it"
        See the fleet
        • RIPFENCE
          • Sep 2009
          • 1332
          i have gone to all 2p configurations which helps...just gotta try to hammer down more thats all..its just tough when its choppy..thanks for the input guys
            • 8012
            When the water is rough or it's windy, prop down to increase WOT time while decreasing speed. Either smaller diameter/pitch, or same diameter less pitch. Sometimes too little diameter means the boat struggles to get on plane.
            • RIPFENCE
              • Sep 2009
              • 1332
              makes sense..you have to go slower anyways because of the chop..thanks fluid
              • SwampNut
                • Jan 2011
                • 45
                It's best to not get OCD and just go enjoy your toys however you feel like using them...
                  • 8012
                  ...except that the way a lot of guys use them destroys the ESC and costs them money. For some reason that isn't fun for most of them. We have to be intelligent about how we use our toys if we want them to last, nothing to do with OCD.
                  • SwampNut
                    • Jan 2011
                    • 45
                    Buy a bigger ESC. I haven't blown one up yet, but have the spare waiting.
                    • JackBlack26
                      • May 2007
                      • 905
                      Hahaha! I agree. Using common sense at WOT will do wonders for your electronics
