I once had a thermal problem after the flexshaft was broken and stuck in the stuffing tube. I lost a carefully polished prop but my 180A survived by luck. I mean check your shaft system, ensure its smooth and low resistance when spins up. An poorly installed/maintained shaft also ccould cause an over heat issue.
What went wrong?
I once had a thermal problem after the flexshaft was broken and stuck in the stuffing tube. I lost a carefully polished prop but my 180A survived by luck. I mean check your shaft system, ensure its smooth and low resistance when spins up. An poorly installed/maintained shaft also ccould cause an over heat issue.Comment
