Ms Geico Twin revisited
  • Basstronics
    • Jun 2008
    • 2345
    As some may know I picked up the Miss Geico twin from Black Cat.
    http://forums.offshoreelectrics.com/...ighlight=geico
    Im looking for suggestions/ideas on motors. I would like to run 4S if possible.
    I combed thru his thread and found some suggestions or used motors:
    Leopard LBP4050/4Y @ 2260 KV
    Turnigy 3656 2600 KV
    Scorpion 3026 1600 KV
    Im a bit shy of the Scorpions or an outrunner as I dont have a means of crafting any water cooling. If I could buy something affordable I would be fine with an outrunner.
    Planned props right now are X447's counter rotating of course.
    Looking to get this rebuild going, soon. Its tax season
  • Diesel6401
    Memento Vivere
    • 4204
    I am running the suppo motors Ben sells. They are similar size & wattage rating to the scorpions and 1600kv. Once i blow these up (if i do) I will grab the same scorpions he used. I am not running any cooling what so ever to my motors and so far so good. Haven't had any issues with them running in a 32" HOR cat...
    - Diesel's Youtube
    - Diesel's Fleet
    • Basstronics
      • Jun 2008
      • 2345
      Ben?
      Got a link to the motors?
      • Diesel6401
        Memento Vivere
        • 4204
        Originally posted by Basstronics
        Ben?
        Fightercat57 is his OSE name. Here's the motor I used. Their the same as the HK motors. Actually mine said turnigy on them. Suppo is the maker. http://fightercatracing.com/index.ph...chk=1&Itemid=1
        - Diesel's Youtube
        - Diesel's Fleet
        • JackBlack26
          • May 2007
          • 905
          Outrunners don't really need cooling unless there is an amperage draw issue caused by too much load. The beauty of them is that since the can spins they cool themselves. The 3424 castle outrunner in my Geico doesn't get over 90*, even on 6s. Don't worry about cooling them. Just go for it!
          • Make-a-Wake
            FE Rules!
            • 5557
            What about these 4 pole 540 XL's.............should have some good power on 4s!
            • Basstronics
              • Jun 2008
              • 2345
              http://www.nitrorcx.com/77p-lbp3674-b-2-5d-2650kv.html
              Im not sure if the longer can will fit. I have a 4074 here so I will see if that will fit today.
              I think the 40 might fit- just run into a length issue.
              I will look into those motors Diesel.
              • Basstronics
                • Jun 2008
                • 2345
                http://hobbyking.com/hobbyking/store...idProduct=9258
                On 5S?
                • maxmekker
                  • 412
                  Here is the typhoon in my boat, not the same as MG, but the surge crusher sure got a move on with the T500 on 5s.
                  watch from 1,40 for 5s.
                  Only thing with that motor is the solder on the wires inside the can, mine fell off with 6s, and it's not a chance to get them back on.
                  I got this now:
                  http://hobbyking.com/hobbyking/store...dProduct=11181
                  Drammen rock City
                  • Diesel6401
                    Memento Vivere
                    • 4204
                    I own this motor as well. Their is someone here running those in a twin just not sure. The motor I linked to at fightercats website is better IMO. I am pretty sure the 3126 outrunner puts out more wattage then the typhoon does.
                    Originally posted by maxmekker
                    That is the same motor I am running that I linked to at fightercat. So far I really like it on 6s it works great. Awesome motors for the price.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • JackBlack26
                      • May 2007
                      • 905
                      The Tacon motors are the same thing for a fraction of the price. Something to keep in mind.
                      • Basstronics
                        • Jun 2008
                        • 2345
                        I stand corrected... The 4074 Leopard will fit...
                        I think thats it... This boat will get twin Tacon 4074 2150's on 4S
                        • DyrtyByrd
                          • May 2010
                          • 146
                          where can you get the tacon motors?
                          • Basstronics
                            • Jun 2008
                            • 2345
                            • Basstronics
                              • Jun 2008
                              • 2345
                              Ok gang the motors will be here tomorrow.
                              Im looking into batteries right now after seeing the Hyperion Vs Turnigy thread.
                              With 2150 kV and X447 props. I will be using the 180 Amp ESC's.
                              Trying to decide between 4S and 5S. I want to buy the Neu batteries while they are cheap. They are only $4 a pack or so more than the Turnigy...
                              So 4S= 31,820
                              5S= 39,775
                              I want to go fast but I got one shot at buying batteries for this...
                              I know Blackcat was a fan of high RPMs... Again or play it safe?
