What motors MHZ
  • dasboata
    • Dec 2010
    • 3152
    What motors MHZ
    Mystic C5000 44.8" cat .the boat came with a motor mount plate with a bolt pattern about 9/16 on center I will be needing a couple of motors FAST MOTORS thanks chris
  • carlcisneros
    • Jan 2010
    • 1218
    how bout a couple of CMB 67 green heads?
    carl
    • dasboata
      • Dec 2010
      • 3152
      carl
      Been there done that thanks I think MHZ answered a e mail I was pretty shocked how fast they did I think that is great , they recommended a 2 Leopard4074 2.5Y 2413 on 4-6s Lipos what do you guys think thanks chris
        That Kv will work on 4S but NOT on 6S. You will need a lower Kv for 6S per motor, probably around 1600. The 4074 motors are similar to the Neu 1521s and should work well for your MHZ.
        • Brushless01
          • Apr 2010
          • 487
          Two castle creation 1717 motors should be a beast.
          Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
          • dasboata
            • Dec 2010
            • 3152
            Jay what kind of speeds do you think I can reach with 4S thanks chris
              Chris, it depends on how long you want to run. Run time depends on pack capacity and motor temperature - heavier motors handle high amp/heat better than lighter ones. Powerwise that is essentially an 8S1P setup and you can prop up to get into the 70s. With 6S per motor, 80s are very doable with that hull. The scale German hulls handle speed better than the US/Canadian racing cats, but they don't turn all that well.
              • dasboata
                • Dec 2010
                • 3152
                Jay Have you tried that prop yet ? I am a little confused you told me to run 4S know you say to run 6 S is that a type o? I would prefer to run the higher Voltage because I think I can go faster with more volts,, am I wrong about this ? you guys are my imformation guys as I am learning thanks for your time chris
                • JMSCARD
                  • Mar 2010
                  • 3444
                  the 4074's are comperable to the 1515 castle or Neu's .... the 4082 is the 1521 equivelant....
                  Also what about a couple 1518's ? 4s and 5s...?
                  • Rumdog
                    • 6453
                    I'd run the CC/Neu 1520's on 6s each. (IF you can find them) With CR x 447's. Ask Tiqueman how fast it is.
                    • dasboata
                      • Dec 2010
                      • 3152
                      4 or 5 what ever is faster I guess 5 ,,,,,447 pretty small I would hope to turn bigger then that but what do i know thanks chris
                      • carlcisneros
                        • Jan 2010
                        • 1218
                        Chris;
                        Remember, RPM = SPEED
                        Thats why I will be running 6S2P power on the insane 45" mono with Twin 1400KV motors and twin props of course.
                        Did alot of homework on this and feel very confident it will go very well.
                        Carl
                        • Rumdog
                          • 6453
                          Tiques HPR 115 with twin 1520's and 447's. Hull is 45", very similar to the Mystic. http://www.youtube.com/watch?v=1yAyT7GdFeI
                          • dasboata
                            • Dec 2010
                            • 3152
                            Wow nice making some r's for sure and speed I could not find Neu 1520 just 1521 TY
                            • oscarel
                              • Dec 2009
                              • 2127
                              The 1520's are the Castle's. 76 with twins, that's impressive!
