Having two kids I use the little yougert containers they like so much. The custard ( I think you call it pudding over there) are the same. Never run out.
I have thousands of disposable dixie cup but the best is silicon ice cube tray or small silicone cake mold!!! dixie cup sometimes melt with heat
why don't you take a cup... any cup... and mold the outside with silicon...
I've been using these little tubs that sugar free drink mixes come in...however my supply is running low. I did find (online) some polypropolene beakers, 15ml $15 for 100(s&h extra).
I found epoxy measuring cups that Great Planes makes, the problem is i had to get them online which is not to big of a deal if you dont need it right away.
Are you sure you are using the correct amounts if you are getting that much heat out of a small amount of epoxy. The only time I have experienced that kind of heat was when I was mixing like a pint of it while I was helping to restore a real vintage hydroplane.
Jim
Billy Graham
had a .5 oz of poly resin in a paper cup that hit 221F when it 'kicked'(glad I wasn't holding it :)). haven't had epoxy get anywhere near that hot(yet). found some small cups at the craft store (3/4 oz.) will find out tonite how well they work(got a motor mount to do)
Never seen anything like that unless it was mixed with the wrong ratios in small amounts
Jim
Billy Graham
when I owned my custom shop, we fabbed an molded custom enclosures, we would have it get that hot on a regular basis. We did mix it a little hotter than usual but it was normal to burn yourself of a kicking enclosure.
