I have a new basic HK Pursuit hull and now I need to gut it and build to better specs.. Power will be a Lepoard 4074 2000kv with x442 prop on 180 ESC running on 4s
I have a couple of questiuons
How does one remove the old engine mount that is epoxied in in order to replace it? Was thinking heat maybe to soften, perhaps using a monokote iron? Cut it out?
There is a pad for the servo, is it better to source and buy a servo bracket or just fabricate one or epoxy the servo in? Suspect the bracket is best, any tips on a good source did not find any on Steve's site.?
Any other hints or tips for a Pursuit build appreciated. I thinking I probably need to up grade the two piece drive shaft as well to a one piece 3/16ths?
Thanks in advance
Peter
Thanks in advance
Peter
