Hey guys just finished up my twin 32 inch fighter cat build and am curious on the output shafts. I noticed they are both right hand threads. Am I going to have issues with my prop nut backing off on my clockwise running motor? If so could I use lock collors instead of nuts? Any of you guys that use this size stinger 4mm what do I need to do to use 3/16 cable with it, I know you can buy reverse flex cable but are the shafts ose sells reverse threads. Do they come with nuts? Sorry they dont go into that much detail on the listing. Was also thinking wire drive but unsure whether it will hold up under a 6s load but then the same issue with clockwise threads. Any help or advise here. I know there are several of you that have built twin cats of similar size hoping you chime in. Thanks, Duane
