Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 best way to cut cf sheet - Offshore Electrics Forums
  • ezhitz
    • Aug 2009
    • 428
    I have a piece of CF plate I want to make a motor plate for my rigger with and was wondering whats the best way to cut it? The young guy at the hobby store said a laser would be good but I didn't think to put one in my hobby room
    Can I use a cut-off wheel in my dremel or is there a better method.The thing sounds like china when you tap it.
    :canada
  • tiqueman
    • Jul 2009
    • 5669
    Cut off wheel will work. I use a scroll saw. I also have a blade mini skill saw gimmick for my dremel that works very well for cutting straight lines using a guide. Wear a dust mask, that stuffs nasty.
    • ezhitz
      • Aug 2009
      • 428
      Thanks for the reply i will wear a dust mask i read before it wasn't good to breath in the fibres.I do have a dremel scroll saw i can try .
      :canada
      • tiqueman
        • Jul 2009
        • 5669
        Dremel scroll saw... hmmm I havent seen that before. I think I need to go shopping!
        • Darin Jordan
          • 8335
          I just use one of my bandsaws.... They are setup with metal cutting blades and seem to work fine.
          Darin E. Jordan - Renton, WA
          • dasboata
            • Dec 2010
            • 3152
            I 2nd that I use a band saw ,,,it will spark good luck it is some hard stuff Chris
            • egneg
              • 4670
              I use a Dremel 4" table saw with a carbide toothed blade. This picture isn't my saw but you get the idea.
              IMPBA 20481S D-12
              • ezhitz
                • Aug 2009
                • 428
                Thanks guys for your input.Sounds like it trial and error to see what tool i have that will work best.I wonder if a diamond tile bit in the dremel might not be a bad idea.
                I attached a pisture of my dremel scroll saw it must be about 20 years old first tool i bought when i started in the RC hobby.
                :canada
                • tiqueman
                  • Jul 2009
                  • 5669
                  Ahh I gotcha, I was imagining it to be a "mini" type. Thats about the size of the one I have.
                  • egneg
                    • 4670
                    I went through a half dozen blades in my scroll saw doing a cut out for the servo.
                    IMPBA 20481S D-12
                    • gultch
                      • Jan 2011
                      • 63
                      has any one tried to use a mill to do the cut outs for battery trays and engine mounts in carbon or carbon/kevlar sheets?
                      genesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progress
                      • tiqueman
                        • Jul 2009
                        • 5669
                        Wearing them out or breaking? The first blade I tried cut decently but only cut out 1.5 motor mounts for a twin cat. The next blade I tried, which I think was a "multi-purpose" blade, has cut out the other half of that motor mount, 3 battery rails w/ slot details, 4 sets of servo mounts w/ details in the sides, Two more sets of twin cat motor mounts, 2 pairs of transom doublers and a few other small parts and its still cutting, although I need to cut more mounts and will probably change out the blade as its cutting a lot slower now. I will have to check exactly what type blade that was for you Chuck.
                        • ManuelW
                          • Oct 2010
                          • 756
                          Hello Guys,
                          as I build quite a lot of boats I also have to cut a lot of CF sheet. Mostly I use my Dremel, but its all about the tools you use.
                          For cutting straight lines I can only recommend the GF fibre reinforced blades with a diameter of about 40mm.
                          Here the link to them at the Dremel Website: http://www.dremel.com/en-us/Attachme...l.aspx?pid=456
                          With max. rpm they cut even through 3mm CF sheet like its butter.
                          And for round shapes, eg. cutting out motor mounts or similar parts I use special milling tools for my Dremel. Here in Germany they are called "Diamantverzahnt", I couldn't find how they are called in the USA. Here a link to a shop where you can see a picture, maybe one finds a shop who has them in stock:
                          Best regards,
                          Manuel
                          • egneg
                            • 4670
                            It would sure help. The blades did not break but all the teeth wore out very quick and they turned blue from the heat.
                            IMPBA 20481S D-12
                            • Jim Bob
                              • Nov 2008
                              • 42
                              Abrasive cut-off wheels, carbide tipped, or diamond. High speed steel will cut it but not long.
                              Product: T Shank Diamond Coated Jigsaw Blades from China at Offers to Sell and Export Dated Wednesday 26 August 2009 1:00 am
