The Triton that has been around the world
  • BHChieftain
    Fast Electric Addict
    • 1969
    Some of you may recognize this boat, as apparently I'm something like the 5th or 6th owner of this hull from this forum...
    Anyway, I bought this late last year on the swap shop, but have been been busy with a bunch of stuff so it took a while to build her out.
    Setup:
    -Castle Creations 1518 1800KV motor (a beast!).
    -CC Hydra 240A ESC
    -5S2P 5000mah (so that's 10,000mah!).
    The 5S2Ps are created with 2 sets of 3S1P + 2S1P wired in series, then each set run in // to the speed controller. The boat has a flood chamber so I like this config vs. 2 large 5S1P packs which would be difficult to place and have the boat self-right. You can see in the pics below how I have them arranged for the boat (the imaginary boat nose would be pointed to the right).
    Hydra 240A ESC makes it handy to run a 2P config, as there are already 2 sets of leads for pos and neg (although you need to bridge these wires together to mix the power correctly).
    Did a test run at the local pond, ran a little 442 prop, runs ROCK solid, probably mid 50's already...
    Pulled the boat in after 2min, then after 5 more min, so 7min so far, everything is cool. I suspect I can hit 10min runtime with so much lipo capacity. After I nail down the runtimes, I'll try an X642 prop.
    Will post some videos in a few weeks when we hit the larger lake.
    Cheers!
    Chief
  • Rumdog
    • 6453
    I ran that same setup in my Rico for a while. It works good! Put a big prop on that sucker and let her rip!
    • BHChieftain
      • 1969
      Here's my son on a run back in Feb. Lovin' it!
      • keithbradley
        • 3663
        Looks great dude.
        A little painful to watch though. If I ever made a mistake selling a boat it was this one. I actually had to dive after it once to save it. Make sure you have lots of flotation! Glad you guys are having fun with it.
        www.keithbradleyboats.com
        • BHChieftain
          • 1969
          Looks great dude.
          We've added a bunch of pool noodles to it. Still tweaking the weight balance on the flood chamber-- if it flips we need to blip the throttle a bit before it will competely turn over (need to adjust the lead weights a little further back I think). But so far so good. Made another video of my son running it today, got airborn a few times... I'll post that later in the video sub forum.
          I've found 2 configs that are working well with the 1800KV motor-- 5S2P on a X442 prop, and also 4S2P on a X642 prop. I think the 5S2P config could take the X642 prop but that'll be too much speed for my son to handle...
          We'll take good care of her for you.
          Chief
