NEU 2215 motor Q
  • don ferrette
    • 1093
    NEU 2215 motor Q
    In need of some info- on the NEU smooth case 2215 need to know the diameter and usable case length for a possible custom cooling jacket. The OSE cooling jacket diameter for the finned case is 3" which is a bit too large.
    - IMPBA Hall of Fame -
    - IMPBA Hydro Technical Director -
  • drwayne
    • May 2008
    • 2981
    -68mm dia.
    -95mm OAL
    -720gm
    W
    • Make-a-Wake
      FE Rules!
      • 5557
      I'm coming up with 63mm dia. x 84mm length
      • RaceMechaniX
        • Sep 2007
        • 2828
        Don,
        I measure 57.5mm or 2.264" diameter on my motor and a useable length of 2.1"
        Neu's sites list 57.413mm for a smooth can.
        Tyler
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • ray schrauwen
          • 9472
          Looks like the Leopard Cooler comes very close....
          Nortavlag Bulc
          • ray schrauwen
            • 9472
            Nope...
            You could just buy 2.5" Aluminum tubing with .0625" wall and just silicone it on or try for the 1/16" orings instead of the 3/32" orings I use for my Leopard 56mm can. I think it will work... I'll crunch numbers....
            Nortavlag Bulc
            • ray schrauwen
              • 9472
              O.k. a piece of 2.5" tubing minus .125" total (.0625 x2) wall = 2.375" ID
              a 2215 with proper sized .0625" cross section Oring on it is approx. 2.389" total OD.
              2.389" - 2.375" = 0.014" or .007" compression per sideof oring. This can work.
              Nortavlag Bulc
