pursuit brushless
  • gokart
    • Feb 2011
    • 5
    pursuit brushless
    hi can anyone tell me the best motor and esc for my pursuit i have been told to use a Etti 150 amp esc and feigao motor running 4s 14.8 volts i also need to no a good prop ive also been told a octura 1.5 pitch is the go can anyone help cheers
  • questtek
    • May 2009
    • 556
    I do not know the "best" set up but have used a Leopard 4074, 2200KV on 4S with great success. Now run a Leopard 4074, 1800KV on 5 S with a three bladed prop and am getting 58 MPH. Both use T-180 ESC's. I would recommend reading all the Pursuit threads and this will go a long way to assisting you.
    • martin
      • 2887
      Was their much difference in speed between the 1800kv on 5s & the 2200kv on 4s. Id also go with something like the T180 esc, The Etti esc are good esc i use some myself in various boats but they are expensive & their only 150amp. When you can get the T180 much cheaper & do the job very well. I also wouldnt go with a Feigao motor, Their are better motors around. Thanks Martin.
      • gokart
        • Feb 2011
        • 5
        pursuit
        Thanks for your help ive been told to get a ETTI Race 150 amp ESC with a feigao 580L and run an 4s which should give me around 100kph with the right prop
        • Alexgar
          • Aug 2009
          • 3534
          i run an etti 150 in a 32 cat with a cc 2200 and have good results
          • Diesel6401
            Memento Vivere
            • 4204
            Also check threads on DF33, information on that boat applies to the pursuit. I run the following setup on my pursuit. No GPS at this time but it's fast as hell and is a pleasure to drive.
            Motor: Leopard 4074 2200kv
            Esc: Seaking 180
            Drive: .187 3/16 flexcable
            Props: Tested a m445, moving up to a modded x447
            Batts: 2x Turnigy 4s 3600mah 30c in parallel
            * on the m445 after a 4 minute run the motor and esc where around 103F-110F. The leopard are much MUCH better motors then the Feigao's and are at a great price. I also run a 4074 1774kv motor in a 29" cat with amazing results. I was running a Cf48 on that 1774kv and the motor never broke 100F on 4s and ran 48mph.
            - Diesel's Youtube
            - Diesel's Fleet
            • Make-a-Wake
              FE Rules!
              • 5557
              I run mine with a Leopard 4074 2200kv on 4s with a T-120 esc and an x442. GPS'd at 45.................runs cool as can be.
              • gokart
                • Feb 2011
                • 5
                thanks guys for your help
