spartan's motor
  • fastisgood
    • Apr 2010
    • 126
    spartan's motor
    Hay guys I needs some help I have traxxas spartan and the motor an esc are done I need a new set up I have a castle1520/1y motor will this work and what size esc do you think I need and prop size for 4s and 6s thanks
  • JMSCARD
    • Mar 2010
    • 3444
    It will work... it will be lots of power... good 5s and 6s motor, I'd run a x442 to start and get the setup right..., then a x445 after you've got the setup close... no question about it... I'd run a Seaking/Turnigy 180 esc!
    • Diesel6401
      Memento Vivere
      • 4204
      All the power that 1520 has is going to wreck havoc on that plastic hull...JMO
      http://forums.offshoreelectrics.com/...splay.php?f=60
      http://forums.offshoreelectrics.com/...ad.php?t=21475
      http://forums.offshoreelectrics.com/...ad.php?t=21380
      - Diesel's Youtube
      - Diesel's Fleet
      • 6sHyper
        <<<Surfs up!
        • Jan 2011
        • 597
        Turnigy/Seaking 180 amp ESC, that castle motor on 6s, with a 42mm prop i would bet you will Rip!! 1600kvx22.2v=35520rpm, heck thats a reliable setup i bet you could even go bigger on the prop.
        • fastisgood
          • Apr 2010
          • 126
          thanks guys I was a gas guy but now Im all electric I also have Whh team pro 43'' gas boat Im making it electric /// On the spartan esc is that a HV 180?
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            No HV on the 180.2-6s lipo.Id run an external BEC or a reciever pack if running 6s.Some people have had luck with using the esc's BEC,but some havent.I run on the side of caution and use an external.
            • JMSCARD
              • Mar 2010
              • 3444
              while I've had luck running the internal bec on 6s.. it does cause the esc to run considerabely warmer, and the fact you will be running it on a good sized motor with some real amp draw I would definately run it on a external bec or reciever pack.. I think the early T180's were the ones most known for bec burnups, but still Its very easy to run external power and your esc will thank you for it...
              • fastisgood
                • Apr 2010
                • 126
                Ok thanks
                  • 9488
                  looking forward to this one!
                  my Spartan should be here sometime this coming week
                  • forescott
                    Hopelessly Addicted to RC
                    • 2686
                    I'd just get a lower kv 540xl with a jacket that covers the entire can and use the stock esc. Something like a 13xl. If the esc still shuts down, get a turnigy/seaking 120. I also think the 1520 will be over-the-top for the spartan hull.
                    • fastisgood
                      • Apr 2010
                      • 126
                      Ok cool I wiil keep that in mine can some one give me some help on 43'' deep hall what size motor in something like this for sport
