timing
  • MARKY C
    • Jan 2011
    • 37
    timing
    what is the best timing mode for a 4pole burshless motor??? its a y wind the motor is the leopard 4082 1500kv
  • egneg
    • 4670
    Depends on whether it is a Y or D wound motor. What motor are you referring to?
    IMPBA 20481S D-12
    • brooks93
      • 89
      typically a mild to high timing mode is used for 4 or more poles but it does depend on the number of poles and windings
      seasoned newbie
      • Diesel6401
        Memento Vivere
        • 4204
        Per Neu
        For most uses the low advance setting is best—motors have better efficiency. “Y” wind motors can use medium advance for a little more power or speed. “D” wind motors should always use low advance as there is no improvement with higher advance settings
        Use low (0-10 degrees)or medium(10-15 degrees) advance settings for “Y” wind motors and low (0-10 degrees) advance settings for “D” wind versions.
        - Diesel's Youtube
        - Diesel's Fleet
        • brooks93
          • 89
          is this for just neu motors or in general? aveox and plett's say higher timing or they did when I was using them
          seasoned newbie
