Suggestions For Drivetrain
  • zrchobbies
    • Jul 2007
    • 31
    Hey guys,
    I have a 12 size rigger fthat I want to go FE with. I was wondering if you all had any suggestions as to wht I shoud put in it. I would like to get the max potential out of the hull. It's 25 inches long. Weighs about 1lb minus running gear. Looking for speeds in the High 50's low 60's I know the hull is capable of that. What motor/speedo/cell combo do you all recommend
    Thanks
    Zach
  • txboatpilot
    • Oct 2007
    • 1494
    I would use .078 wire drive. I run a Matrix Rigger for fun on 4S1P lipo w/Neu 1515/1.5D and .062 wire drive...It has held up fine!!I bought this boat used and it was already set-up w/.062 wire, If I build another I will use .078 just to be safe! Speeds are 45-55 with diff. props...Hope this helps...
    Nothing like keeping you lipos warm and your prop wet!!
    • zrchobbies
      • Jul 2007
      • 31
      thanks. It all helps. Not real familiar what type of speedo/motor combo do you all recommend?
      • zrchobbies
        • Jul 2007
        • 31
        I guess i should have worded it differently I was wondering about the motors/speedo/cells
        • txboatpilot
          • Oct 2007
          • 1494
          Look at Neu motors and CC esc's...You will need good equipment to go that fast!! Look into Lipo batteries..Thunderpower has very good packs....
          • zrchobbies
            • Jul 2007
            • 31
            good deal, I was thinking 12 cells/or lipo, not sure on the esc size or motor size
            • txboatpilot
              • Oct 2007
              • 1494
              Look at the Hydra 120 or 240 to be safe!! Look at 1512/2D or 1515/1.5D both will work....And be very quick on 14.8V or 4S1P lipo...These motors have tons of POWER on lipo's......
              • zrchobbies
                • Jul 2007
                • 31
                thanks tex.
