Cutting long straight lines
  • Ub Hauled
    • Aug 2007
    • 3031
    Let's hear of solutions from you guys...
    How are you guys cutting long straight lines in sheets of wood?
  • JimClark
    • 5907
    thin plywood?
    Billy Graham
    • Ub Hauled
      • Aug 2007
      • 3031
      yes Jim, 3mm (around 1/8")
      but maybe for thicker pieces as well...
      • CornelP
        • May 2009
        • 745
        Send the drawing to the laser cutter... :p
        • JimClark
          • 5907
          That thick I would use my table saw thinner I would do with a razor blade or wheel cutter and a metal straight edge
          Billy Graham
          • Ub Hauled
            • Aug 2007
            • 3031
            eventually... yes!
            right now I have to cut out the parts for my prototype and then once I finish the fitting the design will be updated and lasered to make it easier.
            @Jim, thanks.
            • Chuck E Cheese
              • May 2008
              • 1684
              i dont have a table saw so i use a jig saw. i set up a fence with 1/8 alum bar stock clamped to the wood. after the cut with the jig saw i clamp the bar stock to the cut edge and sand it. the sand paper only cuts the wood, not the bar stock so it comes out straight.
              see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
              • Ub Hauled
                • Aug 2007
                • 3031
                interesting idea... I don't have a table saw either... nor do I have room for one... I may need to clean up the "cave" a bit.
                thanks Chuck
                • properchopper
                  rcgoatbuild@snotmail.com
                  • 6968
                  Jan, how long is the piece ? When I make rails for a mono, I get a "close enough" cut with a sabre saw, then finish mill it with my belt sander which has a 12" span.
                  • ncornacchi
                    • Jul 2009
                    • 251
                    how about a skillsaw with plywood blade,,,clamp long straight-edge on wood to cut...
                    • sailr
                      • Nov 2007
                      • 6927
                      Cutting a straight line on thin stock is a B-E-A-T-C-H! I cut as straight as possible on my scroll saw and then finish with the belt sander.
                      Mini Cat Racing USA
                      www.minicatracingusa.com
                      • Chuck E Cheese
                        • May 2008
                        • 1684
                        whatever you do just make sure to use the right blade so you dont tear it up. the guys on the boat next to me have been doing some wood work and had a table saw down there. i ran to the shop and bought a bunch of 1/8 and 1/4 ply. i just ripped the sheets into 1",1 1/4, 1 1/2 and made a pile of strips to have for next time. now i have about 4 of each in 1/8 and 1/4 sitting in a drawer.
                        • egneg
                          • 4670
                          I have a 4" Dremel table saw that I got at a flea market about 25 years ago. I picked up a bunch of blades and other accessories from Micro Mark 20+ years ago. It still works great after all these years. This picture is not my saw but you get the idea.
                          IMPBA 20481S D-12
                          • siberianhusky
                            • Dec 2009
                            • 2187
                            Never tried this but...
                            screw a jigsaw under a plywood "table" with a slot for the blade to come up through. Now clamp a level or some other straight edge for a fence the right distance from the blade and paralelle to it and rip away.
                            I imagine you would have to do a fair bit of sanding to clean up the edges.
                            If I tried it I would look for the widest blade I could find thats pretty fine toothed, that should run straighter and not chew up the plywood.
                            You can buy a fence contraption that bolts do a drillpress that works in conjunction with a sanding drum as a small thickness sander. I've seen them advertised at luthier supply places for small home shops.
                            Luthier places are actually a great source for small tools for people who build. My favorite tool is a miniature block plane with a 1/2" wide blade.
                            Cheers
                            • 785boats
                              Wet Track Racing
                              • Nov 2008
                              • 3169
                              For anything up to 1/8" ply I just use a 3' steel rule as a straight edge & a Stanley knife. Might take 3 or 4 passes on the 1/8" ply but it's a nice clean cut on the line. Anything over that it's the trusty old 16" Ryobi scroll saw.
                              Cheers.
                              Paul.
