cooling issues
  • toddilgen
    • Oct 2007
    • 72
    cooling issues
    guy's i'm stumped, when i run my cat at full throttle water stops coming out of the hole in the side of the hull, but when i back of the throttle and slow down water starts coming out again. my cat is set up with the rudder in-line with the prop, and the hole in the rudder is drilled in line with the prop thrust. what is going on i am stumped on this one. help!
    ALL OUT POND BASHING MANIAC!!!:D
  • ReddyWatts
    • 1711
    Can you try a longer rudder?
    ReddyWatts fleet photo
    • toddilgen
      • Oct 2007
      • 72
      not really, don't want to start taking the boat apart. want to see if i can fix whats already on there.
      • FRED
        • Jul 2007
        • 233
        cooling issues
        No comment.
        • toddilgen
          • Oct 2007
          • 72
          do you mean dremel out the groove and open it up more?
          • Steven Vaccaro
            • 8721
            Does it come out when you turn at full speed?
            • toddilgen
              • Oct 2007
              • 72
              yes it does the groove is on the right side of the rudder if you are standing behind the boat. when i turn right it comes out.
              • Steven Vaccaro
                • 8721
                normally a single drive will need some left rudder defection in order to go down the straight away in a straight line. With the inlet on the right, sometimes the water doesn't flow into the inlet because of this.
                • G Doggett
                  • 446
                  Maybe the pick up hole is too high.
                  You say it is in line with the prop blast but sometimes the cone shaped blast has a low pressure area in the centre.
                  It is better to have the rudder water pick up below the prop, in fact as low as possible.
                  On my gas cats ( sorry, swear word I know ) I have the water pick up in the bottom of the rudder to get the high volume of cooling water they need.
                  Graham.
