battery bullets
  • dano1
    • Dec 2010
    • 403
    battery bullets
    What do you pro's recommend for the battery bullet connections, in a build right now and need some nice pictures if ya have any???
    dano
  • domp444
    • Jul 2009
    • 846
    I think most people use bullet plugs, I do too. I have 5.5mm ones on my lower amp setups, and for my current high amp setup I will try to get some 6mm LMT bullets. They have the least resistance and deliver over 200a. There are also the 8mm bullets here at OSE which a lot of people use all around on all of their boats.
    SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
    • sundog
      Platinum Card Member
      • Feb 2009
      • 878
      I use 8mm on all my larger (5000mah battery) boats and Deans on my smaller boats. But if I were starting over, I'd use the new EC5 connectors instead of Deans. I just have too many to re-solder!
      Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        I use HK 5.5's on the motor connections and HK 8mm on the battery connections.I have had no problems,but have only run 6s set ups too.
        • sailr
          • Nov 2007
          • 6927
          5.5's on motor and battery. No problems up to 6S for me.
          Mini Cat Racing USA
          www.minicatracingusa.com
          • dano1
            • Dec 2010
            • 403
            ordered a butt load of 5.5mm so as soon as they get here i'll be busy. thanks guys (again) for the input.
            dan
            • jamespl
              • 742
              I use ec5's and have no probs. I have had deans melt on 4s before now!
              • dano1
                • Dec 2010
                • 403
                Thats what im trying to avoid here, so far i have been lucky....im sure in time that will change.
                • LarrysDrifter
                  Big Booty Daddy
                  • May 2010
                  • 3278
                  I would use a minimum on 5.5's on everything,unless its an HV set up.
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    and the Castle 6.5's are hard to beat
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      I rock Hk 5.5's as well or if HK is out of them Ebay ones.
                      To stop the ends from possibly touching and short out the battery I place 1 large shelfing end cap on the + wire which should be a female plug. These large caps fit the female perfect I got mine at Home Depot http://www.amazon.com/ClosetMaid-Lar.../dp/B000GKSMCM
                      - Diesel's Youtube
                      - Diesel's Fleet
