Brushless O.B getting wet?
  • Andris Golts
    • Jan 2011
    • 504
    Hi all im running a Feigo 9xl brushless motor on top of my R.E.K lower unit as a outboard i have flipped the boat several times having the motor submerged i use compressed air to blow all the water out where the 3 motor wires exit let it dry and re-oil the bearings having this has happen on more than a few times .Would this eventually degrade the performance of a brushless motor? Regards Andris Golts.
    Yes it will eventually cause damage since you cannot blow out all the water. Instead or using air, I'd flood the interior of the motor with a product like CorrosionX or even WD-40 to displace out the water. These products would be much more effective than just air and the CorrosionX would leave a protective coating inside the motor for the "next time".
    • FastVee
      • Aug 2008
      • 649
      I guess it depends what you use and on what but I have destroyed 2 motors while cleaning the water out.
      Both broke when the windings seperated from can/the glue that holds the winds lost grip.
      first time this happened to sv motor after I dunked it in denat.alchohol, second(also sv motor) did the same after I cleaned it using CRC or wd40(cant remember)
      And next outing after the cleaning....-motors broke.
      I guess that better made motors can widthstand chemicals better.
      But after these I have used only compressed air and taking the motors apart and cleaning every bit seperatly with a rag that has wd40 on it -but not too much.
      Bearings I used to clean with brake cleaner and then spray gun oil and everything is nice! (now I lube the bearings with avid bearing oil, nice stuff)
      -Pate
      www.youtube.com/rangerpate
      • sailr
        • Nov 2007
        • 6927
        Just a small squirt of corrosionX will do it. Not that big a deal for em to get wet!
        Mini Cat Racing USA
        www.minicatracingusa.com
        • FloatDaBoat
          Bare Bones Fabricator
          • Sep 2009
          • 368
          Any oil/solvent that dissolves the insulation coating the motor windings will result in a short, destroying the motor & possibly the ESC.
          • sailr
            • Nov 2007
            • 6927
            CorrosionX will not hurt the insulation, etc. NEVER use WD40 or equivalent.
            Mini Cat Racing USA
            • Andris Golts
              • Jan 2011
              • 504
              Thanks to all for the great information. Regards Andris Golts.
              • byron
                • Dec 2010
                • 65
                Why do you say ,not to use wd40.
                • sailr
                  • Nov 2007
                  • 6927
                  WD40 os known to deteriorate some plastics, vinyls, electronics, etc.
                  Mini Cat Racing USA
                  • byron
                    • Dec 2010
                    • 65
                    Were could I get corrsion x, I 've never seen it in Canada.
                      Try here: http://www.offshoreelectrics.com/pro...hp?prod=corr-x
                      I've used WD-40 to dry out BL motors for years with zero problems (sensorless BL motors are not "electronics"), but today I use Corrosion-X.
                      • Kris Flynn
                        #2 Bench Racer
                        • 229
                        I flood the motors a couple of times with Metho (Denaturate Alchohol) a shake it out after a few seconds.
                        Motors are fine after 3-4 years of getting wet on outboards
                        Kris
                        • HOTWATER
                          • Nov 2008
                          • 2323
                          Hey Kris...after cleaning with denatured alcohol (or CorrosionX) how long do you typically let the motors dry out before you run them again...let's just say on warmer days?
                          -Kent
                          "Will race for cookies!"
                          IMPBA D12
                          My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
                          • Kris Flynn
                            #2 Bench Racer
                            • 229
                            Hey Kent, a couple of minute I guess, I just run them and do a good clean at the end of the day.
                            I also find that with my adaptors, when I oil the flex the oil gets up into the front bearing (close to coupler) and wicks its way up to the top beaings, so it self lubes
                            • HOTWATER
                              • Nov 2008
                              • 2323
                              Good deal...thank you sir!
                              IMPBA D12
