water cooling a esc
  • dasboata
    • Dec 2010
    • 3152
    Originally posted by FloatDaBoat
    According to PropperChopper, the nipples are threaded. He posted in another thread that he replaced the originals with 90 degree banjo fittings in order to gain lateral clearance.
    yes they are !!! pics to follow tomorrow when I get it done I will be using 2 barbs only thanks chris
    • dasboata
      • Dec 2010
      • 3152
      Just completed my version of ScarabChris' idea for the SeaKing 180A ESC Cooling enhancement - - in pictures . . . .
      so you opened up the inside like this mine will be a little different
      • FloatDaBoat
        Bare Bones Fabricator
        • Sep 2009
        • 368
        Originally posted by hyrulejedi86
        That is GENIOUS! How did you attach the 90* fitting to the inside of the cooling area and what did you use to seal on the metal plate? I can't find that other thread you mentioned.
        The bypass tube isn't 90 degrees, it's straight with 45 degree angles filed on the undersides to prevent epoxy from blocking the openings when the end plates were added (the 1st pic only shows one end beveled - - needed one end square to stand-up for the pic). I used a Dremel to grind the opening, then used a small amount of 5 minute epoxy to hold the tube until the end plates were attached using Marine Epoxy, which I added pigment to in order get the blue color (natural color is white).This epoxy is very viscose & doesn't run like regular epoxy does. It stays put where applied when used in reasonable quantities.
        Properchopper's Herb Stewart Tunnel Hull build
        • FloatDaBoat
          • Sep 2009
          • 368
          Originally posted by lectriglide
          If you haven't checked already, make sure to remove the heatsink to make sure they are getting good contact with the FETs. Many instances of only a few (like 1/4) of the total FETS contacting the thermal tape the mfg uses. Just want you to get the maximum benefit of your outstanding mod.
          I'm aware of that possibility. After I run this ESC in the hydro I'm building, I'll check the temperature, & if it runs cool, I won't have to mess with the Heat Sink/FET contact patch - - why bother? Lots O Luck !!!
          • FloatDaBoat
            • Sep 2009
            • 368
            Thanks for all the compliments. I'll try no to get too swollen of a head - - HAW !!!
            • DISAR
              • Aug 2007
              • 1072
              Excellent idea!!!
              What I noticed in mine is that the caps are the ones which get way hotter than the rest of the esc. The temps on the caps may be 140-150F and on the cooling plate 86F.
              http://www.rcfastboats.com/
              • dasboata
                • Dec 2010
                • 3152
                Well answer my question !!!
                • dasboata
                  • Dec 2010
                  • 3152
                  #23
                  Check it out
                  What do you think all sealed with honda Bond and red locktite SS water fittings and SS 10/32 the I opened the 2 inside water channel I think it came out pretty good for using hand tools Thanks chris
                  • lectriglide
                    • 538
                    #24
                    Looks GREAT, but let us in on the secret of how you opened it up. Dremel with a looong bit?
                    • Jeff Wohlt
                      • Jan 2008
                      • 2716
                      #25
                      The screws and fittings are the key to keeping it sealed and bolted on. This is the best one yet I have seen.
                      www.rcraceboat.com
                      [email protected]
                      • dasboata
                        • Dec 2010
                        • 3152
                        #26
                        Yes Dremel 1/8" ball ,,, agressive cut . I have been a dremel hacker for over 25 years I would of prefered to use a Mill but I don't have 1 LOL,,, I wounder if FloatDaBoat opened his,, I did not see any pics but then again how would that work ??
                          #27
                          It is normal for the caps to be the hottest part of any ESC. The outside of the cooling plate will be the coolest as it is 'insulated' from the ESC board. Internal ESC temperatures will be higher of course, sometimes by 40*F to 50*F from datalogging. Also remember that the ESC cools off as soon as you stop running so it was hotter than you measured.
                          Chris sure did a great job on the cooling plate, not that I'm surprised given his background.
                          • ray schrauwen
                            • 9471
                            #28
                            That is a Cool Mod. I may give it a go.
                            I might also try to make a Cap cooler, circulate water around them one way or another...
                            Nortavlag Bulc
                            • hyrulejedi86
                              • Aug 2009
                              • 494
                              #29
                              Where are you getting the metal for this?
                              • carlcisneros
                                • Jan 2010
                                • 1218
                                #30
                                If it is Aluminum, you can go over to Lowes and look around the hardware/tubing section. They have various lengths, bends, thicknesses ect.
