SAW 8s setup?
  • nate
    • 1652
    SAW 8s setup?
    1527-1Y 1250 Kv on 8s...What prop for SAW run's, And a prop for a more reliable longer run's?
    Going on a single drive Cat hull in upper 30" -40" range.
    Using hvCC180
    LMT
    LehnerMotorenTechnik.com
  • K.R.Joye
    • Feb 2010
    • 1046
    At 37K no load your just breaking into SAW revs more like an oval setup. I would stick with a lightweight 40"ish Cat start with a X447/3 & work your way up to X452/3. Detounged 3 blades, skegged struts & offset rudders work best on big Cats! Aeromarine makes a nice Sprint-Cat in that size. Careful with that controller on such a large setup (marginal).
    ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
    ****2008/9 MMEU LSO, 2008 LSH CHAMP****
    ~~~~~~~70 MPH Club Member!~~~~~~~~~
    • G1ST
      • Dec 2010
      • 348
      Sorry for the New Guy question, but what is SAW?
      • Chilli
        • Jan 2008
        • 3070
        SAW stands for straight away. They are usually top speed record attempts. You run two passes in opposite directions on 1/16 mile straight course. The set ups for these boats are very hot as the equipment is pushed to the limit so they can only make very short runs before .
        Mike Chirillo
        www.capitolrcmodelboats.com
        • G1ST
          • Dec 2010
          • 348
          Nice! Sounds like Top Fuel for FE.
          Thanks for the info
          Greg
          • NativePaul
            Greased Weasel
            • 2761
            More like Bonneville, its for top speed not drag racing.
