refurb nitro hydro to fe any suggestions
  • gultch
    • Jan 2011
    • 63
    just bought this cmb45 carbonfibre hull rtr for a steal
    any suggestions on a single motor setup that might be equivalent to the 7.5cc nitro motor in it now advertised speed 70 mph
    not sure on hull dimensions yet will update when i pick up in the nxt few days
    genesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progress
  • gultch
    • Jan 2011
    • 63
    maybe a leopard or castle 1527 motor on 8s
    • don ferrette
      • 1093
      A .45 size nitro rigger is far too small for 8S, a 4S would probably be about right for that size hull.
      - IMPBA Hall of Fame -
      - IMPBA Hydro Technical Director -
      • larryrose11
        • Jun 2010
        • 757
        Pretty sweet boat there. I would suggest flexibility. These hulls have little prop slip, and todays motors do best with high RPM. Make sure you ESC you sellect can handel high voltages / cell count. The cheaper ESC's have a lower voltage range. Same for the Motor Also, make sure that the motor is rated for the same current so it will be protected.
        • Scott T
          • Oct 2007
          • 590
          Many guys here are running 45 sized FE riggers on 6S1P with a Neu 1521/1Y. Boats are in the 36 - 38" range. Speeds are virtually the same as the 45 guys (faster as some events). Other options could include a 1524/1Y, 1527/1.5D or 1527/1Y if the boat is a bit bigger.
          A good 4S2P setup might also work well, but we don't run those here, so can't really comment.
          Scott Tapsall
          Pine Rivers Model Powerboat Club - Facebook Page
          My Gallery
          • gultch
            • Jan 2011
            • 63
            thanks guys for the info
