new here but not new to boats
  • dasboata
    • Dec 2010
    • 3152
    Hi guys as some might know, I have a model boat prop business, I want to build an AM 36" sprint cat electric not looking to brake the bank, here, but I am looking for good stuff that is easy to use I would like to go 70mph, if possible, and it sounds like I need to run 10 lipo's is this possible and any suggestions on Motor ESC and Lipo is much appricated thanks Chris
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    What is your budget, this will be expensive, as you are looking at high quality motors, ESCs, batteries, etc.
    Douggie
    • carlcisneros
      • Jan 2010
      • 1218
      hope this works>
      The guy is here on the forum.
      i am sure he will chime in and give you a hand .
      Carl
      • dasboata
        • Dec 2010
        • 3152
        Douggie
        You think a grand would be enough ? there abouts is OK
        • forescott
          Hopelessly Addicted to RC
          • 2686
          I would send a pm to rumdog. He has used a few different setups in the sprintcat, all with great speed and sucess. He can give you some good feedback on a reliable budget friendly setup. I'm sure he'll chime in soon!
          • dasboata
            • Dec 2010
            • 3152
            cool !!!! now thats what I am talking about thanks alot Chris
            • video200
              • 837
              Originally posted by carlcisneros
              hope this works>
              Carl
              http://www.youtube.com/watch?v=wW5O3sMSBkE
              damn that thing handles
              • Doug Smock
                Moderator
                • 5272
                Hey Chris, welcome to OSE!!
                For you guys that don't know, Chris is one of the best prop guys in the business and his service lacks nothing.
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • carlcisneros
                  • Jan 2010
                  • 1218
                  hey video200;
                  thats the way all the aeromarine cats handle.
                  if they dont, then the owner has really messed something up.
                  Carl
                  • Flying Scotsman
                    • Jun 2007
                    • 5190
                    Batteries $200, ESC $200, motor $300, Hardware $200 and that is budget stuff, apart from the motor... plus charging equipment
                    Douggie
                    • dasboata
                      • Dec 2010
                      • 3152
                      Doug
                      Thanks Doug , it is a pleasure to be here,,, thanks for the nice words !!! Any recomendation on the sprint cat I want to build thanks chris
                      • mm123521
                        • Sep 2010
                        • 150
                        Chris
                        Check out this link:
                        http://forums.offshoreelectrics.com/...%27s+sprintcat
                        I am trying to copy Rumdogs build also.
                        I have two sets of motors Castle 1520's and 1518's. (only using one set at a time ). motors and batteries mounted low in the sponsoons.
                        Will be running 6s 5000Mah . I have X442 and x447 counter rotating props.
                        Mostly done, but cant try it out till spring (water is frozen solid here).
                        Home built motor cooling jacket & motor mount for the CC motors. They mount to the 4 inch rails.
                        Home built rudder and stingers.
                        Home built cooling block for cheep chineese 200 amp ESC's.
                        I am just starting out in FE, Rumdog & others here are the experts.
                        Mark
                        Avatar is the dangerous end of a Gatling Gun!
                        • Doug Smock
                          Moderator
                          • 5272
                          Chris I think I'd consider a single motor like the Neu 1527 1Y and run it on 6s2p.
                          The results seem to be mixed with the high volt ESCs. I run Shultze controls in my HV applications but they are a bit pricey.
                          http://www.offshoreelectrics.com/pro...u-1527&cat=117
                          http://www.offshoreelectrics.com/pro...ef-sword-240hv
                          http://www.offshoreelectrics.com/pro...ra180-highvolt
                          I'm sure some others will chime in here soon.
                          Good luck with your project,
                          I'll send you a PM on cells.
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • RaceMechaniX
                            • Sep 2007
                            • 2821
                            Hey Chris welcome to the OSE,
                            Another low budget option would be to buy one of the Castle 1717 motors currently on sale and use a Turnigy or similar 180A controller on 5S2P. A single motor might be able to get you to those speeds without breaking the bank. For budget minded set-ups, its hard to beat Turnigy lipo packs.
                            Another option would be to buy two 1717's or two 1520's from Castle's sale page and use the T180A esc's. You could probably get away with one 5s or 6S pack per motor if you choose a high capacity pack.
                            As soon as you go over 5S, the controllers get pretty pricey. If this is your first FE build stick with something below 6S which will keep the budget in check.
                            Some prices to consider;
                            Castle 1717: $70 per motor while they last
                            Turnigy 180A esc; $90 per controller
                            Turnigy lipo packs range from $50 to $100 per pack depending on te number of cells, capacity and discharge rate.
                            Don't forget about a good charger, I would recommend the Hyperion Duo. They run about $250.
                            So for a twin set-up;
                            Castle 1717's x2=$140
                            Turnigy 180 x2= $180
                            Turnigy 5S 5000mAh packs x4= $312
                            Hyperion charger: $250
                            for a grand total of $882 plus a servo and connectors and your are right at your budget.
                            Tyler
                            Tyler Garrard
                            NAMBA 639/IMPBA 20525
                            T-Hydro @ 142.94mph former WR
                              • 8012
                              ...I want to build an AM 36" sprint cat electric not looking to brake the bank, here, but I am looking for good stuff that is easy to use I would like to go 70mph..
                              Chris, I don't think anyone has asked you what you expect from the boat. Will you sprint race it at 70 mph? Do you want to run for five minutes by yourself? Do you want to make a few SAW passes and bring it in to check the GPS? What you want makes a BIG difference on how you rig the cat, and some of the suggestions above will not meet some goals.
                              My SprintCat 40/60 runs a top end 6S setup and runs in the low 60s in race water. It will finish 8 laps on the 1/6th mile course with ease and is very competitive, but due to heat buildup three minutes is about tops for run time. That is typical for an FE sprint race setup.
                              A single motor is the easiest way to go although twins have their advantages. Twins would allow you to run 5S on each motor for a lot of power and still keep you out of the more expensive high voltage speed controllers - but you have to buy two of them. The chief disadvantage of twins is relatively few prop choices.
                              But I have a strong recommendation first. I know from plenty of experience with gas guys transitioning to FE that starting with a high power boat is not a good idea. Making what is really a simple wiring mistake can cost you hundreds of $$$ in a split second. Most gas guys have a lot of trouble keeping water out of their hulls, and since electronics and water don't mix the result is often costly damage.
                              Unless you have an experienced successful FE boater nearby to help you hands-on with the build, I highly recommend that you get a more simple FE boat first to learn about running an FE boat. Then once you have made the mistakes you can begin your high power SprintCat build. A good choice is the ProBoat Miss Geico RTR cat. This is a good entry level boat which you can upgrade for a lot more speed, or sell later without taking a big loss. Please think about it. And welcome, I have run your props for years and won a lot of races with them!
