....while underway.
I had one of those RAM bilge pumps in my 54" Fountain and after one run it failed. Not sure why but it just doesn't work.
So then I was looking at this fitting......
http://www.offshoreelectrics.com/pro...?prod=gnd-4191
The claim is that you can use the discharge side to suck the water from the hull at speed. Must work on some kind of venturi effect.
Anyone try something like this? I think as long as long as you make the suction loop higher than the outside water lever it should work..
I do understand the theory behind the venturi effect very well, thats how I know it must be set up perfect or it won't work. Just curious to know if anyone has a formula for this that works.
