Need a source for a 6mm prop shaft and bushings
  • Boomer
    • 285
    I have a friend in desparate need of a 6mm OD prop shaft to accomodate a 4mm shaft, that is at least 7" long. He needs the bushings to go in the ends as well.
    Suggestions are invited!!
    Thank you
    Boomer
  • JimClark
    • 5907
    Mcmaster carr should have it
    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
    Billy Graham
    • Boomer
      • 285
      Thank you Jim. I have passed your lead along. Jeff W. said he might be able to come up with solution as well.
      Thanks again.
      Boomer
      • Jeff Wohlt
        • Jan 2008
        • 2716
        Sure I can turn them out of brass but looks like if Carr has them that wouldbe the easiest and probably cheaper way to go.
        www.rcraceboat.com
        [email protected]
        • Boomer
          • 285
          Thanks Jeff. I think John may have gone out of town for the weekend. Once I speak to him, I will confirm if he has found the right tubing.
          It was good chatting with you and thanks for the help
          Boomer
