Twin 1717 Rio 51
  • RIPFENCE
    • Sep 2009
    • 1332
    Originally posted by Brushless01
    Yeah thats what I was thinking. Would I get away with 200amp speedos as there half the price of the 240 ?
    i would not recommend it with that big of a boat and how heavy its going to be..6s on these motors is the upper range especially with the bigger props needed to push that hull...in the end a 240 amp esc is the wise thing to do...no one ever said biulding and powering a big boat with twins is going to be cheap!!! do not cut the corners on the esc...just my opinion
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
    • Brushless01
      • Apr 2010
      • 487
      Thanks !
      Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
      • Brushless01
        • Apr 2010
        • 487
        I have seen a 50 inch cat build with the same motors running T180's so the 200 might work.
        • Diesel6401
          Memento Vivere
          • 4204
          Thanks what about mounts these maybe ?? http://www.offshoreelectrics.com/pro...od=ose-drmount
          I like the vac-u-pickle mounts. I use one in my skunkworks cat. Works awesome! http://www.vac-u-boat.com/BrushlessMotorMount.htm
          The .187 3/16 cables would be a lot better then the .150 you listed before. I would use these, that motor is gonna put out some serious torque!
          The 180 & 200 may work in the long run, I don't like pushing the esc's to their max voltage though. That's just me. I would use the 240HV's...
          - Diesel's Youtube
          - Diesel's Fleet
          • RIPFENCE
            • Sep 2009
            • 1332
            a vee hull draws more amps then a catamaran..just something to keep in mind
            • Brushless01
              • Apr 2010
              • 487
              Thanks guys much appreciated. I just dont think I can afford the extra cash for the 240 amp esc's at the moment. Do I have to plug one motor in differently to the other to get it to spin the opposite way ?
              • Diesel6401
                Memento Vivere
                • 4204
                Plug it up the same way, check the direction if it's not the direction you want switch around any 2 wire connections on the motor/esc.
                - Diesel's Youtube
                - Diesel's Fleet
                • JMSCARD
                  • Mar 2010
                  • 3444
                  I would run Seaking/Turnigy 180s with 1717's way before running the 1717's with the hifei 200.. the turnigy 180's have a burst rating of 360 amps whereas the swordfish 200's have only a 230 burst I believe.... I would run a 1717 with the t180 in a second... just me... especially in a twin motor application... less amp draw....
                  • Brushless01
                    • Apr 2010
                    • 487
                    Thanks JMSCARD should I run an external B.E.C also ? Could I get away with using EC5 connectors on the battery side ?
                    • JMSCARD
                      • Mar 2010
                      • 3444
                      YES definately run a external BEC or Rxr battery pack ..
                      also I myself would run bullet connectors.... 5.5mm or 6mm on batts, and 8mm on the motor side... this project should have them....
                      • Brushless01
                        • Apr 2010
                        • 487
                        Thanks cant wait to start on this build ordering the motors over the next few days.
                        • Team FFRB
                          • 328
                          #27
                          Looking forward to seeing a vid on this boat
                          HOT RODS ON WATER
                          • Brushless01
                            • Apr 2010
                            • 487
                            #28
                            Thanks guys !!
                              • 9488
                              #29
                              One 1717 would push her 40mph.
                              Wow, I did not think one would push this big hull that fast, cuz that's faster than stock
                              I am using 2 of my 3 1717 motors for other builds, maybe 2 of my 1520s on 6s in my Rio 51z would be sweet
                              • JMSCARD
                                • Mar 2010
                                • 3444
                                #30
                                40mph might be a little embelished but would be real close...
