Y connector using 5.5 bullets.....
  • ScarabChris
    • Oct 2010
    • 752
    So easy I feel stupid for not thinking of it on my own. I did this in about 30 seconds. Clamp the two females in a vice, heat them up with a propane torch, apply solder then set the male on top and fill in with solder.
    If I take one minute I can get them perfectly straight. Shrink wrap and it will look pro-peshinal!
    • properchopper
      • 6968
      I've found that the "notched end" 5.5's are easiest to solder together making Y connectors.
      • Doug Smock
        Moderator
        • 5272
        Originally posted by lectriglide
        I tried making some almost like John's method, but the wire stands kept separating.
        Tin the ends of your wire, then strip it.
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          Originally posted by m4a1usr
          You dont need to use any wire to make a "Y" connector. All the wire amounts to is increased resistance. All you need is something like this. Unless you need additional wire length due to wire routing inside your hull.
          John
          John, what an elegant solution and the hat is off for stating you learnt this from an RRR member. There is a commercial opportunity here...OSE?
          Douggie
          • egneg
            • 4670
            These I made have worked well even when racing.
            IMPBA 20481S D-12
            • dasboata
              • Dec 2010
              • 3152
              [QUOTE=D.Smock;264628]Are you wanting to parallel packs?
              Doug[/QEdit wrong post
              • Steven Vaccaro
                • 8723
                I use k&s brass tubing. Slide the brass though all the holes. Hammer the k&s end so it opens up and tightens them all together. Then solder. This gives both a "glued/soldered" connection and a "mechanical" connection.
                • Alexgar
                  • Aug 2009
                  • 3534
                  #23
                  do you have a pic steve?
                  • properchopper
                    • 6968
                    #24
                    I love that idea ! Will give it a try.
                    • Steven Vaccaro
                      • 8723
                      #25
                      I will do one tonight for you.
                      Andy Kunz once told me a soldered joint is never enough. Alway have a "mechanical" connection. If things get a bit hot, the joint wont pop. That bit of info has never failed me.
                      • Jeff Wohlt
                        • Jan 2008
                        • 2716
                        #26
                        I was planning on brazing mine. Wonder if a little arctic silver would be good between those?
                        www.rcraceboat.com
                        [email protected]
                        • dasboata
                          • Dec 2010
                          • 3152
                          #27
                          ME 2 I am not following you !! The part about hamming them ??
                          • dasboata
                            • Dec 2010
                            • 3152
                            #28
                            The connectors look and feel like cast with a gold plating, I think brazing might be too hot and melt the castings but LMK I have some silver soilder and rods here Chris
                            • m4a1usr
                              Fast Electric Addict
                              • 2038
                              #29
                              What Steve is saying is the bullet connectors have holes in their sides. Both the male and female. Since the solder arraingement is to have them laid along side each other you align those holes in each bullet with the tubing running thru all 3 pieces. With his method you "flare" or crimp the ends of the tubing to draw the 3 bullets closer to each other. In other words,.......the tubing sticking out of the 2 end bullets is where you use your dikes to cut the tubing. Or take a hammer and flare the 2 ends as described. Either way you do the same thing.
                              I like a solid conductor running between my 3 bullets. Thats why I use the 10ga wire. To each his own. We both use a mechanical reinforcement method to retain the bullets together in conjunction to the solder.
                              John
                              Change is the one Constant
                              • HOTWATER
                                • Nov 2008
                                • 2323
                                #30
                                I'm thinking that it's just like hammering out a rivett on both ends (using the brass tubing as the "rivett").........
                                -Kent
                                "Will race for cookies!"
                                IMPBA D12
                                My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
