question on dual prop Genisis.
  • teamchrome
    • Jun 2010
    • 68
    Im looking at the Genisis boats.
    I like the cats and this one seems to be a nice start.
    Any thoughts to this one here or should I look elsewere??
    Thanks, Chuick in Seattle.
  • Doby
    KANADA RULES!
    • 7280
    I would look else where..while the hull is good, looking at the pics, it seems to have "knock off" 6XL's in it...also the add states that he's running 2770 kv motors on 6S! That over 60,000 rpm!!!!
    Just a tadd to much unless all you want to do is run in very short bursts.
    Check out Fightercat, on this forum if you are looking for this hull and possibly a twin set up.
    Grand River Marine Modellers
    • Alexgar
      • Aug 2009
      • 3534
      that rpm would blow up nice motors, i agree with doby, doesnt mention the escs either which means theyre also cheapies. this boat is 192 when i add it to my cart, so you are buying a bunch of junk you will have to change out for$125
      • teamchrome
        • Jun 2010
        • 68
        Thats what I needed to hear.
        Just need HK to get the Genisis in stock.
        Single drive will save my wallet for awhile also
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3278
          Fighter has the genesis.his version is called the 37" daytona.
          • teamchrome
            • Jun 2010
            • 68
            A single drive with a Leopard 4082 or a Fiego sounds nice
            Would a Seaking 120 or 180 be good with one of these motors?
            • Alexgar
              • Aug 2009
              • 3534
              the pursuit is in stock not the same but a 179 dollar alternative, 4082 would work fine but id lean towards the t180 i think 120 will be pushed to close to its limit resulting in failure in a couple runs
              • GP73
                • 544
                Save yourself the trouble and buy a Daytona from FighterCat, he has everything.
                FighterCat
                • teamchrome
                  • Jun 2010
                  • 68
                  FighterCat
                  Very nice!!
                  Cant wait to see a duel set-up on this hull.
