I have the typhoon. Its pretty powerful for its size, but if going the outrunner route I would use the castle 1800kv's. They are slightly larger and only 40-bucks a piece with the castle sale.(plus I wanna see how well they work)
Diesel, I think that the Typoons will be pretty under powered for that size hull.
Ok thanks, what about the outrunners Forescott listed?
Those look badass, maybe a winner, let's see with the twin experts think. Good price that's for sure.
I think chuck e cheese used the typhoon in his hotr cat and was running 50-60 if I recall correctly.
I'm no prop guru but I beleive de-toungued props has lees holeshot and more top end. But with twins you have twice the blade area so it doesn't make much matter. Adding cup and or pitch will redirect the thrust cone so you'll have more speed. Counter rotating props are limited in sizes so alot will be modified.
Big heavy and powerful. Gonna need some room for the batteries this baby will use. I have one I bought in the swap shop and was gonna run in the Geico but dont have a 6mm to .150 coupler.
FE BOATING: Less like a hobby and more like an addiction!
without trying to steel the thread d,,,,how do u rate motors to see what rpm they will run etc? i am doing the same thing with a twin and dont have a clue what motors to use///
Looking good Diesel! Not sure how fast you want to go but I just installed the Leopard 2860 2730kv in my 25" Prince mono and it runs awesome. Setup is 3s 5000mah 30c Turnigy, 3/16drive /.150 flex spinning a x637 (for now) and hit 40mph with low temps. My batts were 94, esc 70 and motor was 80 after a 5 minute run. I like this Apparition hull and am wanting to get one. Can't wait to see the finished product.
My bad. I'm not familiar with the HK outrunners. My little brain was thinking "T" = typhoon. Now back to your usuall programming.......lol
Originally posted by LarrysDrifter
The T-600 sounds sweet.Anyone have a link?Are they good for a twin set up?
Just so all of us are on the same page this is the motor I have http://www.hobbyking.com/hobbyking/s...idProduct=9258. I planned on using in a BJ26, but I also have suppo outrunner coming that I can use instead. Since i have one and they are priced cheap they may be worth a try. Once I open the motor mount to except 25mm bolt patterns the sky is the limit. It maybe worth a $50 try for fun. I love that outrunner sound!
Blackcat, Larry and Tiq. Did you guys looks at the CC outrunners Forescott posted yet. Opinions on those?!?
