Water Cooling
  • fast
    • Nov 2010
    • 96
    Water Cooling
    I know this is a electric form but I have a gas rc boat I am building and I need to know if there is a way to cool it(weed eater engine) with water.
  • AlanN
    • Mar 2008
    • 334
    Your should run a water cooled head on the motor. Air cooling is ususally not enough. If the head isn't milled for water cooling you might want to get one.
    A good gas motor builder/retailer is: http://www.mastonsrcmarine.com/
    • Chilli
      • Jan 2008
      • 3070
      Here's a pic of the stock Zenoah gas motor (about $200). You can see the black cooling jacket that surrounds the head. Most boats also gets cooling at the exhaust flange (where the header bolts up to the block) and mine gets addtional cooling where the tuned pipe connects to the header. My rudders has dual pickups.
      Mike Chirillo
      www.capitolrcmodelboats.com
      • fast
        • Nov 2010
        • 96
        Its a weed eater motor tho.
        • m4a1usr
          Fast Electric Addict
          • 2038
          The old trick used to be to turn down the cooling fins on the head using a lathe and then cut the end off an alum baseball bat for the cooling jacket. Now you can buy after market jackets on Fleabay as well as heads already modified for your motor. Just keep an eye out they show up from time to time.
          John
          Change is the one Constant
          • Chilli
            • Jan 2008
            • 3070
            Found this old link for a Homie. Maybe some useful info for you.
            Mike Chirillo
            • monojeff
              Moderator
              • Nov 2010
              • 2562
              What is your reason for wanting to cool it?
              A lot of the weed eater engines are fine without cooling them unless they are modified then they typically need to be cooled.
              Try this forum http://www.rcuniverse.com/
              you will find all the info you need.
              Depending on the motor you have http://www.majorsmackdown.com/ has water jackets and can do the machining for you.
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
