adhesive/epoxy recommendation
  • RIPFENCE
    • Sep 2009
    • 1332
    hello peoples,
    I AM WORKING ON MOUNTING MY HK4035'S MOTORS IN MY 44 INCH CAT..I HAVE NO WAY OF USING NUTS AND BOLTS TO MOUNT THE MOTOR MOUNTS IN THE HULL...SOOOO I HAVE TO USE SOME SORT OF EPOXY/ADHESIVE TO ATTACH THE MOUNTS TO THE HULL...I WILL FIBERGLASS THEM IN ONCE THE ADHESIVE IS SET...WHAT WOULD YOU GUYS RECOMMEND TO DO THIS...KEEP IN MIND THAT IT MAY HAVE TO WITHSTAND A LITTLE HEAT AND BE SUPER STRONG..ANY THOUGHTS?
    THANKS FOR THE TIME
    RIP
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • Gerwin Brommer
    • Dec 2008
    • 918
    FIRST QUESTION IS :
    What material are the mounts made of ?
    • RIPFENCE
      • Sep 2009
      • 1332
      Yes that question makes a whole lot of sense doesn't it...its machined aluminum mount from south river rc
      • tsenecal
        • 58
        i have used this stuff to glue wood, metal, and acrylic to polyester and epoxy resin fiberglass:
        system three T-88
        I have a boat that has acrylic and styrene glued to polyester built in 2004 that is still holding strong. styrene is supposedly difficult to glue to other materials.
        • dana
          Banned
          • Mar 2010
          • 3573
          west systems marine epoxy is excellent stuff, also slow setting epoxies work better than fast ones.
          • JimClark
            • 5907
            I also use System Three General Purpose Resin
            Jim
            Billy Graham
            • RIPFENCE
              • Sep 2009
              • 1332
              Jim
              i gotta try some of this stuff..looks like a real good product..time to step up from the household grade to the real stuff..thanks a lot guys
              • Gerwin Brommer
                • Dec 2008
                • 918
                Can you give a link to the exact mounts ?
                Which type/brand of epoxy you'll use, isn't that important.
                More important is prepping the mounts and the hull.
                • RIPFENCE
                  • Sep 2009
                  • 1332
                  here are the mounts and how they are going to sit against the inside of the hull..the legs of the mount are going to be glassed in after they are epoxied in..unless anyone has a better idea then i wiould go with that
                  • yurkanip
                    Banned
                    • Jul 2008
                    • 420
                    Agreed with what all of you had to say. I have done a lot of epoxy/glass work making molds etc. West systems is amazing stuff...the slower setting, the stronger the bond. Period.
                    Prep is the key, as already mentioned. Sanding the area to be glassed, with 80grit...wiping down with denatured alcohol...then sand your part to be glassed, wipe down with alcohol etc...and apply glass/epoxy. With recoats, or more layers once the first is dry. It is key to scuff the surface again. Applying epoxy, is in a weird sense, somewhat similar to prepping and area for paint.
                    • DISAR
                      • Aug 2007
                      • 1072
                      yes, good sanding of both surfaces to be rough, then 24 hour epoxy mixed with microbaloons (the final form to be very viscous like putty)
                      http://www.rcfastboats.com/
                      • befu
                        • Aug 2009
                        • 980
                        I also use laminating resin for structural attachment. Much stronger than the fast hobby epoxies. Instead of all micro balloons, I will also use milled glass fibers to add strength, or kevlar pulp if I want it realy strong. Use some micro balloons to lighten up the density. Very very strong.
                        • RIPFENCE
                          • Sep 2009
                          • 1332
                          A vendor less then a mile from my house sells the system 3 stuff!!! Lol i am going to get some now thnaks guys
