I was wondering how hard is it on the motor running it above its max amps?
Running a bj26 motor 1500kv 45 amps in my df29 on a m445 prop its peaking around 78 amps but running between 50-60 amps.I'm using a turnigy 120 amp esc so thats not a problem. Outside temp is cold so after 6 minutes of running everything is just warm.Boats running upper 30's on that prop but I don't want to kill the motor if the amp draw is to high.If I thin the prop more and bar cut could maybe lower the amp draw.
Thanks Jack
Thanks Jack
