Supplier of Premade Stringers
  • 427srule
    Racer
    • Nov 2008
    • 164
    Does anybody have an idea who sells Pre-made Stringers?
    Thanks,
    Mike
  • westbeach
    OSE Rocks!
    • 951
    Why do you want pre-made stringers? They are pretty easy to make, you just need to cut them out of plywood. What hull are you planning on building up?
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • 427srule
      Racer
      • Nov 2008
      • 164
      I am building a Cyber Storm and wanted to install Stringers. What is the best kind of Plywood and how thick should it be?
      • westbeach
        OSE Rocks!
        • 951
        The plywood that I used for my stringer is 1/4" thick plywood. What type of motor mount are you going to be using? It is best to cut out your stinger shape out of cardboard first to see how everything attaches to it before committing to cutting out a good set.
        • 427srule
          Racer
          • Nov 2008
          • 164
          I plan on using a 4" Rail mount from South River Boats. The cardboard as a template is a great idea and will eliminate trial and error.
          Thank you,
          Mike
          • westbeach
            OSE Rocks!
            • 951
            Found the thread about the DF Cyberstorm. http://forums.offshoreelectrics.com/...ce+cyber+storm
            • 427srule
              Racer
              • Nov 2008
              • 164
              The pictures REALLY help with laying everything out. Have you added trim tabs yet or are you still running without?
              Thanks,
              Mike
              • westbeach
                OSE Rocks!
                • 951
                Still running without trim tabs. Seems to be running great without them.
                Thanks,
                Mike
