You are correct something is dead wrong and his prop selection is it (besides motor choice not being best of course). The grim 44x66 is a lifter designed for hydros and riggers and shouldn't be used on cats. Change that prop and I bet things happen.
prop ? for bj26
yeh... no question, also have you calibrated the esc to the tx?Comment
Throw in 2, 3S packs in parallel(total of 11V) and hang on!! I would do 2, 3200 mah packs for a total of 6400 mah. At 20C each that's 40C too so that's an advantage. Might have to try that on the one I'm building!
If the cheap, stock, 2900kv motor in my Widowmaker rips on 2S, I can't imagine how fast that 2650kv 4 pole motor would be on 3S in a tad bigger boatComment
For the apparition 4mm issue use a shim http://www.offshoreelectrics.com/pro...?prod=ose-1030 and use 3/16 drive props. Will give you more of a selection. I have the same hull coming in the mail and I'm dumping the 4mm system for some .150 3/16 flexcables.Comment
Lifter prop does exactly what the name says, "Lifts". They have a lot of pitch and lift the transom out of the water. 3 point hydros and riggers run on the very edge of the sponsons and pretty much the prop, the transom is normally out of the water, that's one way how the achieve such high speeds less of the boat in the water = less friction.Comment
All the props I have listed require to be sharpened and balanced before use on the boats (especially the octuras), the grim props come close, but still require attention. If you don't know how to sharpen and balance yourself Chuck here on the forum does a great job and is a pleasure to do business with. If you want to start with some CF props that don't require S&B the CF42 is just like a x442, CF45 is like a x445 and the CF48 is like a x448. The CF42 can be used with the UL1 motor and the CF45 can be used with the CC1512 1800kv motor, and if the temps check good you can very carefully try the CF48. This is until you get the other props S&B'd, metal props are going to provide better performance because the don't flex under load.Comment
You don't have to buy the MG flexshaft. Buy a hugey or a octura shaft or even a wire drive. Im just using what I have for twins, it worked out better that way for me. If your using a CC 1518 or 1520, buy a bigger shaft to handle the torque like a .187 3/16 shaftComment
keithbradley-Senior Member
"Just to make sure this is clear because people ALWAYS get confused on this...
Simply put, when parallel connecting two batteries, dishcharge rate doubles, but c rating does not.
They are not the same thing, and thats what causes a lot of confusion. Discharge rate is the amount of current a pack (or packs) is capable of safely discharging. C rating is a number given to packs to help you determine what the discharge rate is. C rating never doubles. If your pack is 40C/5000mah and you run another pack of the same rating in parallel, you will have double the discharge rate (400A), but the C rating is still 40C."Comment
