I noticed the Traxxas 2075 digital servo buzzes in my Pursuit when it's powered on. Is that normal/okay?
Traxxas 2075 buzzing?
No more buzz! I guess it's the small bend in the steering linkage that's causing the force. That's okay, right?SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y'sComment
Should be fine but I find this extremely annoying. The rubber seal boot on the back of the transom is probably the culprit. It probably has tension on it when the servo is in the neutral position. Try sliding the boot on the linkage rod until it finds a spot that it is relaxed.
"IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"Comment
Yeah it is! Haha. I don't think it's the rubber seal boot, since I find that to get the linkage with the horn on the servo I have to fight it a bit. Not in a dramatic way, there's just a bit of tension since it isn't perfectly straight. As long as it's okay, it doesn't bother me :)SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y'sComment
