How do you calculate volts = rpms?
  • britscoot
    • 656
    For example i have 2 motors i'm comparing to run on 5s.
    Castle 1515 1y 2200kv and a Castle 1518 1y 1800kv.
    The 1518 is longer and has more cogging.
    Which one is going to perform better (speed) in a 30" hydro?
    sorry for all the questions.
    cheers
    • 9488
    The 2200kv motor on 5s is 40,700rpm!
    and the 1800kv motor on 5s is 33,300rpm, that's much better imo
    the 1515 is more of a 4s motor
    2200kv x 18.5volts = 40,700rpm
    • ERCM
      • Oct 2010
      • 10
      kv x volts will give you rpm. 5s is 18.5 volts x 1800 kv = 33300 rpm
      • ERCM
        • Oct 2010
        • 10
        He said it better lol.
        • britscoot
          • 656
          I have run the 2200kv motor on 5s and it comes in warm except the lipo gets too hot for my liking.
          It's very fast.
          Will i be able to achieve the same speeds with the 1800 motor with different props?
          What is the advantage of running the 1800 motor?
          • britscoot
            • 656
            what i meant to say is that i'm using a H6 prop on the 2200,so could i use an H7 with the 1800.
            If that makes sense....lol
              • 9488
              It's very fast.
              The bigger motor has more torque so it will swing the bigger prop easier and possibly keep the packs from getting so hot
              I say give it a try and see how it performes for you
              and you may want to try 6s just for kicks on that motor
              Is this in the FE30?
              • britscoot
                • 656
                When you say bigger motor,do you mean the 1800 will swing bigger props?
                And yes this is the FE30.Doing mid to upper 60's on the 2200/5s.
                So the 1800 on 6s will be crazy fast?
                • teach
                  • Jun 2008
                  • 509
                  That's still 40k rpm.
                    • 9488
                    That's sweet getting your FE30 to those speeds!
                    yep you should be able to swing the bigger prop on 5s with no issues, and running 6s for a SAW type run
