New boat!!
  • domp444
    • Jul 2009
    • 846
    Well, if there isn't any other water exit port then that'll be it.
    SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
    • RCKong
      • Sep 2009
      • 1545
      Looks to me like it had all - in - one, or inline rudder and strut, with the hole being for the rudder pushrod seal. I would get some UL-1 hardware and put it on. You will have to drill for the rudder though. It would be on the left side of the strut. If your nervous about setting the rudder, maybe this will help. I ALWAYS drill thru the holes on the rudder bracket itself for accuracy. Using 2 sided tape to stick it in place. drill one hole and put a bolt in it, snug it up and drill again repeating with the bolts. It's hard to screw it up this way.
      RCK
      • Krowbar69
        • Sep 2010
        • 237
        Ok... i looked at it today and...yes i think it was a water outlet... no other holes in the hull.. and yes i think i was a strut rudder combo.... wonder if i can get one that will work..
        • domp444
          • Jul 2009
          • 846
          Yeah it's got to be the water outlet. And I think someone linked you to a strut/rudder combo earlier in the thread that would work.
          Also, check out my thread about my first Pursuit run.
          • T.S.Davis
            • 6220
            Get this
            Same bolt pattern. Just flip the rudder bracket over to the left side. That extra hole on the right was probably a water exit or something.
            Noisy person
