I picked up a CastleLink so I can set up my Hydra 240LV for my DF 33" Hyperion 4S1S 5000mah battery I will be running two of them and a Octura X 442 I have set the LVC at 12v timing set to normal were I can use some help with is the Throttle Curve not sure what to do ??
Setting UP Hydra 240LV
I leave the throttle curve alone. Some like to set the full throttle end point at 90% to make sure they have full throttle, but I have not seen a need.
What motor are you using? That will determine the timing setting, which is one of the most important.
