So I have been wondering for a while now but when looking at the feigao motors I noticed that they each give a max wattage as well as a link which shows the feigao motor chart.
Now taking the 540L as an example.
The wattage is 700 watts:
Using the W=V x A formula:
~ running 6s means 31.5A
~ running 4s means 47.3A
~ running 3s means 63A
Once you look at the chart that shows the Max amp per kv configuration they are very different.
My question is how do you really know what to look at to figure out what's best for your project? Using different input voltages would change the amp draw, right?
I.E. If I knew I wanted the 12L rated at 51A max what voltage does that correspond to? Do you look a 51A to plan ESC and batts or do you take the wattage and use the formula based on which cell configuration you want to use to figure your ESC and batts?
Sorry for the length question but thanks for the clarifications!!
