Balance ppoint on a DF26
  • carlcisneros
    • Jan 2010
    • 1218
    Anyone know the balance point on the DF26 hull?
    Thanks
    Carl
  • Brushless01
    • Apr 2010
    • 487
    I was wondering the same
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    • carlcisneros
      • Jan 2010
      • 1218
      Anyone???????????????????
      • siberianhusky
        • Dec 2009
        • 2187
        27-30% good starting range for a mono. Then move batts around until you get the ride you want. I start with everything neutral and only make one adjustment at a time until it runs right. Try to get it running as well as you can by adjusting the strut/stinger, rudder angle and cg, I try to use trim tabs as a fine tuning aid and not a solution to bigger problems.
        SOme guys start without trim tabs on the boat and only add them if the need them.
        • carlcisneros
          • Jan 2010
          • 1218
          Thanks husky.
          will start there and then adjust as needed.
          Carl
          • Rumdog
            • 6453
            Yup. It all depends on how fast you'll be pushing it as well.
