lipo question
  • britscoot
    • 656
    lipo question
    i have 2 lipos same brand.
    both have the same voltage and c rating.
    They have different amps.
    Can i safely run these in parallel.
    cheers
  • Make-a-Wake
    FE Rules!
    • 5557
    cheers
    Are you meaning that they have different mah ratings?
    • britscoot
      • 656
      Yes,one is 3300 and the other is 2300.
      Everything else is the same.
      thanks
      • Make-a-Wake
        FE Rules!
        • 5557
        You'll drain the 2300 quicker obviously...................and the continuous amps provided will be different. For example, if they are both 20c.......the 2300 will put out 46 continuous amps, and the 3300 66 cont. amps. Personally i wouldnt do it.
        • britscoot
          • 656
          Ok.
          i appreciate your help.I was hoping it would just give me more usable mah.
          Thanks again!
          • bwells
            • Jan 2009
            • 842
            Good question and a good answer. This is what this forum is about.
