Twin Outrunners on a Hydro?
  • Dangerous_Toys
    Hiding from the Ole Lady!
    • Apr 2010
    • 2250
    Originally posted by Fluid
    Use 1/4" cable, absolutely. You will eventually break a 3/16", but the 1/4" will be pretty much bullet proof.
    Should the 1/4" cable be stepped down to a 3/16 shaft to accommodate 3/16 props or should that stay at 1/4 shaft also to run the larger 1/4 props?
    ? WHAT RULES?
    • Dangerous_Toys
      • Apr 2010
      • 2250
      So, should I go with a 1/4 shaft as well as a 1/4 cable? Anyone?
      ? WHAT RULES?
      • don ferrette
        • 1093
        1/4" cable with step shaft to 3/16" should be fine, will give you a greater selection of props. Most 1/4" bore props are a bit much for FE.
        - IMPBA Hall of Fame -
