Motor KV chart
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    Originally posted by scullyeng
    Wish it went to 12s
    -s
    You can use Excel and create your own chart. It's a quick calculation; Here's a .doc, because I wasn't allowed to attach an .xls.
    • ReddyWatts
      • 1711
      This is the kind of data I like to see posted. It has been a long timing coming. Good job, Detox
      ReddyWatts fleet photo
      • Steven Vaccaro
        • 8721
        Cool stuff.
        Now integrate what sizes should be used with what voltage and physical motor size.
        • Steven Vaccaro
          • 8721
          xls has the ability to have executables in it. So its a no, no for user up-loadable data. But if you send it to me I can host it.
          • Alfa Spirit
            • 2131
            For mono hulls or for cats?
            RPM for a mono hull = apprx. 30000RPM
            RPM for a cat hull = apprx. 35000RPM
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              Ah! Dayum viruses.
              I'll make up a spread sheet with a few common calculations and send it your way.
              • video200
                • 837
                good one mate. thank you for the chart. now saved for future referance :D
                • FloatDaBoat
                  Bare Bones Fabricator
                  • Sep 2009
                  • 368
                  #23
                  Another .XLS
                  Here’s a Clipboard image of an XLS spread sheet I whipped out . . . .
                  • carlcisneros
                    • Jan 2010
                    • 1218
                    #24
                    Float;
                    can you send me the actual spread sheet with calculations inserted?
                    Thanks
                    Carl
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      #25
                      We should conglomerate and improve on FE Calc. I guess it would start with determining a structure and what factors and formulas to calculate.
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        #26
                        here's a test. Download the file (save link as) and then change the file extension to .xls (remove .doc)
                        • properchopper
                          • 6968
                          #27
                          Sorry for my lame computer skills, but is this a way to get a working version of your "calculator box" ? If so, could you expound, step by step, how I can get one up on my cormputer ?
                          Thanx,
                          Tony
                          • chummer
                            • 636
                            #28
                            Thank God I'm not the only one that is computer illiterate
                            "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
                            • lectriglide
                              • 538
                              #29
                              Fighter- the motor kv chart would be sweeeet if we could pick beginning & ending kv, kv increment, and # of cells in a data area, then let the chart populate. This would allow maximum flexibility for all cell count applications even the 12s+.
                              I really like the chart approach to see the multiple kv and rpm's together.
                              • lectriglide
                                • 538
                                #30
                                Thanx,
                                Tony
                                Tony, just right click on the file, select "Save Target As" then at the top drop down box "Save in" select say "desktop". It will download. then go to your desktop and find the downloaded file. Right click and select "rename", Then backspace over the ".doc". This will change it to an *.xls file that you can open with excel.
